Old 02-20-2009, 12:35 PM   #1
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
Default Rc8 brake question.
I just changed over to a Xtreme racing carbon brake disk from the factory RTR disc well there is no braking i adjusted the brake bias and still very little brakes. Well i measured the distance between the brake pads and they are set a 4.5mm thats what the manual says, the thickness of the two diffrent brake rotors are pretty close to being the same within 1mm of each other. Should i adjust the spacing between the brake pads to like 3.0mm to get the braking i need?
Thanks for any help!!
Lance Plant
Sponsors: Team Associated~Reedy~LRP~Pro Line~Avid RC~Airtronics~Werks Racing
TXRC8racer is offline   Reply With Quote
Old 02-20-2009, 01:42 PM   #2
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
Yes, I would adjust the brake plates because it sounds like there is too much room... you might also want to scrub the discs so that they are slightly rough in order for them to grab more.
clinttredway is offline   Reply With Quote
Old 02-20-2009, 03:56 PM   #3
t0adman's Avatar
+1 for the above. The gap is very precise and 1mm makes a big difference. I would make the gap 3.5mm and see if that solves the problem.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 01:30 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
