Old 02-20-2009, 09:48 AM   #1
Default Roto Start VS. Bump Start
Which one is better?
rsmith569 is offline   Reply With Quote
Old 02-20-2009, 09:53 AM   #2
golferdude1971's Avatar
Trader Rating: 18 (100%+)
Bump Start. Reason being is that the rotostart has something like a one-way bearing connected to the crank, which actually adds to the amount of rotational mass.
golferdude1971 is offline   Reply With Quote
Old 02-20-2009, 10:02 AM   #3
revo61's Avatar
Trader Rating: 18 (95%+)
Bumpstart, no one way bearing to wear out or go bad. Also more engines use a bumpstart, very few work with rotostarts.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 02-20-2009, 10:13 AM   #4
markr04's Avatar
I'm still using roto start on my 8ight RTR. I think it's convenient, especially if you want to bash, but they develop a common problem. The one-way bearing begins to slip and it turns freely... meaning it doesn't turn the engine over.
I can still use the roto start, but I have to do it in short bursts until it finally grabs. When the engine is warm, it's not a problem. You can use a heat gun to help it along, but if you're bashing you may not have easy access to a heat gun.
My 8ight is not even 2 months old. My friends who also have the roto start all have the same problem.
The starter box is better. I use it for everything but my 8ight RTR, but you can have only one or the other (at least for the 8ight). The roto start backplate requires that the engine is lifted a bit higher, too far up for a starter box to touch the flywheel. You can convert to use starter box, though, by getting a normal backplate and a different engine mount. They are about $50 together.
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 02-20-2009, 10:17 AM   #5
Pullstart!!!!
I wish I could use a bumpstart but the only one that can is my Traxxas Nitro Sport, the one-way bushing went bad on it and now I need to replace it.
howtowakeakar is offline   Reply With Quote
Old 02-20-2009, 10:21 AM   #6
Jaz240's Avatar
Trader Rating: 52 (100%+)
Roto-starts are a pain in the butt, and allot more expensive in the long run, especially if you put an aftermarket roto-start on an engine that is not designed for a roto-start..Like everyone says the bearing, and/or the shaft will strip out and must be replaced, mostly because the roto-starts are too strong for the engine, they spin too fast and ruin everything..Bump start is the only way to go, at least until someone comes up with a Turnkey...
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 02-20-2009, 11:02 AM   #7
t0adman's Avatar
Huh? My starter box spins way faster than a roto-start and neither one is as fast as the engine when it's idling let alone revving up.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Old 02-20-2009, 11:09 AM   #8
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Maybe he has a 40000 RPM roto start.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 02-20-2009, 11:14 AM   #9
Jaz240's Avatar
Sorry, I didn't word that right..I meant it spins too fast for the one-way bearing to handle. One ways, and the shaft that turns them are made for Pull-starts
Old 02-20-2009, 11:25 AM   #10
plus2ss's Avatar
Bumps starts are ideal, but if your dealing with a vehicle like my LST2, the only option is a roto-start. Kinda sucks when your racing, but they do make some pretty gnarly roto-satrt motors, I know RB and Novarossi both make a good roto-start motor. I saw a guy on the LST forums that converted a O.S. 28xz from a bump to a roto-start. Anything is possible.
plus2ss is offline   Reply With Quote
Old 02-21-2009, 12:04 AM   #11
Never really had the one way bearing wear out. Sometime they will slip from the oil in the fuel.
pdmustgt is offline   Reply With Quote
Old 02-21-2009, 02:39 AM   #12
The Roto starters suck. I hate those thing. My truggy has one and I hate it. If you flood your engine, you can burn out the one way bearing. It sucks a lot.
Dvx400Rider is offline   Reply With Quote
Jammin X1x vs Hyper 8/8.5 RTR Tcaputo Nitro Off-Road 15 07-15-2009 01:47 PM
novarossi n21b rotostart vs os 21vg rotostart kra2y Nitro Off-Road 10 05-07-2009 08:36 PM
Huge F'up, need help! boatsnhoes Nitro Off-Road 14 05-04-2009 08:42 PM
Duratrax Universal Starter Box VS Losi 8ight -T RTR elkman Nitro Off-Road 6 04-27-2009 06:40 PM
RC8 RTR vs Losi 8ight RTR vs Jammin X1 RTR sidewaze Nitro Off-Road 30 12-30-2008 06:23 AM
