Old 02-19-2009, 06:45 AM   #1
sidewaze's Avatar
Default Minimum outside temp to break-in engine
Bought my boys each a Hyper7 and they're chomping at the bit to run them. Just curious what the minimum outside temp should be to start this. I told them probably not until atleast 50 deg. Just curious hoping to have them start during their March break. The motor is a Hyper .21 and I have hot and medium plugs.
Team Novak [email protected] | Pinnacle Freight Specialists www.pinnaclefreight.ca
Trick Parts Trick-Parts.com Stainless Steel screw kits lifetime warranty
Xray T3'11 Havoc Pro SC/17.5 Ballistic| Xray T2'008 Havoc Pro SC/21.5 Balistic CVTA
WGT CRC Gen-X 10LE Havoc Pro SC/17.5 Ballistic| CRC GenX Havoc Pro SC/17.5 Ballistic
Action Hobbies Kingsville | Lou's Speedway Dorchester www.lousspeedway.com
sidewaze is offline   Reply With Quote
Old 02-19-2009, 07:13 AM   #2
vti-chris's Avatar
Rap the head with a sock or aluminum foil and always have the body on.
Temps will go up and you can break it in with no worries.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 02-19-2009, 07:14 AM   #3
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
A beer coozie works great too. I kept a heat gun on my motor almost the entire time I was idling tanks through it to keep the temp around 200.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 02-19-2009, 07:15 AM   #4
Trader Rating: 19 (100%+)
You are right on the temp, the plugs is your choice the hotter the bigger tuning window. Check the for recommended plug and wrap the heads with the thick alum foil not that cheap dollar sore stuff.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 02-19-2009, 07:51 AM   #5
sidewaze's Avatar
My concern is the outside temp as I'm currently 19 deg. I would assume to properly combust the fuel you'd want a more moderate outside temp. Not only that but the engine would probably cool too fast.
Old 02-19-2009, 07:54 AM   #6
At that temp a heat gun is really your only option when idling tanks through it. The engine won't retain enough heat at break-in speeds when it's that cold outside.
Old 02-19-2009, 08:32 AM   #7
rced1's Avatar
We race indoors with the doors open at colder temps than that. I like to break my motors in at 40 degrees or higher because it is easier to keep the temp of the motor up and I do not wear gloves during the process.
Cold air actually equals better combustion. The tuning of the motor will make a big difference on break in. As the others suggested, use a heat gun and aluminum foil to get the temps up and heat cycle the motors.
Slow is fast.
rced1 is offline   Reply With Quote
Old 02-19-2009, 05:17 PM   #8
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i have broken motors in at 20 degrees but i prefer it to be warmer.. i would say at least 40 for best results
jamminnay is offline   Reply With Quote
