Old 02-17-2009, 01:49 PM   #1
Default clutch bell and spur gear size
i've recently bought a ansmann terrier kit and bought a .28 picco engine. I've had difficulty stopping the bell and gear from shreadding eash other so i was wondering if my spur gear might be a bit dig or small for the clutch bell any ideas if you all know what i'm on about??? thanks
mosh86 is offline   Reply With Quote
Old 02-17-2009, 02:50 PM   #2
Sounds like you have a gear mesh issue, keeping your gears meshed properly will stop most issues. Also is your motor mount moving?
CarCrazy is offline   Reply With Quote
Old 02-17-2009, 02:51 PM   #3
nope mount aint moving.i've moved the engine about loads of times to try mesh them but i just cant seam to get it. should most 1/8th scale spur gears fit?
Old 02-17-2009, 03:17 PM   #4
wallot's Avatar
gear mesh is easy .
loosen the motor mount so motor can be moved easily
take a piece of standard paper. cut a 10mm wide 100mm (1/2"x4") long strip. fold in half so its bit thicker or just get bit thicker paper
put it between spur and clutch bell push the motor onto the spur and tighten the motor mount . now just pull the paper out and it should go out with bit of a force but not rip . now u got a perfect mesh.
i never stripped a single gear on any of my cars.
thick paper works on mod 1.0 gears in 1:8 scale thinner on 32p and smaller teeth (48p, 64p)
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
Logan Off Road ( The Brickyard ) Brisbane QLD BIG O Australian Racing 10325 03-08-2017 03:07 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Which 1/10 gas car to get? x_man Malaysian R/C Racers 45 06-30-2003 03:19 AM
