Old 02-16-2009, 08:16 AM   #1
Default savage won't start
i have savage 25 with ofna .26 force (same engine as the 25) it won't start. glow plug/ starter is fine. everything spins and makes noise but cannot get it to start. fuel goes into to carb won't start and i tryed i put fuel in the carb and started but only on the fuel that was put in. tried hsn (richen/lean) i use trinity monster fuel...... any suggestions.
Ofna force
ofnaforce is offline   Reply With Quote
Old 02-16-2009, 12:26 PM   #2
snowboard094's Avatar
The idle screw might be to lean or rich. Try adjusting it.
snowboard094 is offline   Reply With Quote
Old 02-16-2009, 12:53 PM   #3
Funking-Awesome's Avatar
Trader Rating: 30 (100%+)
Default plug
Hey mate you might want to check the plug. Even new one's can be shot already. Even if you go by what your ignitor says, you can't always be sure.
That's just my suggestion
Good luck
Funking-Awesome is offline   Reply With Quote
Old 02-16-2009, 01:11 PM   #4
losi_racer's Avatar
Trader Rating: 25 (100%+)
Good luck
x2....
if thats not it, and if ur tune is right, then you prob have an air leak somewhere but it still should start even with a leak
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 02-16-2009, 01:37 PM   #5
Madbrad's Avatar
Trader Rating: 29 (100%+)
Make sure there is nothing stopping the fuel from getting to the carb. Like clogged filter or something. Reset the needles back to factory spec's and then try it from there.
Madbrad is offline   Reply With Quote
Old 02-16-2009, 05:57 PM   #6
u said it runs when you add fuel through the carb manually. That def. says that it is not getting fuel from the tank. If it makes it to the carb itself, then there is something in main needle passage. Take the needle completely out and make sure it is not broken off, or has trash in there. Do a thorough inspection of the carb. Lowside as well, just make sure its clean and free of debris. If it runs when you put fuel in it, its not a glow plug or ne thing like that.
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 02-17-2009, 04:32 PM   #7
Default savage working
thanks for all the help i fixed it yesterday mourning. it had an air bubble in the tubing to the exaust. thanks again
Ofna force
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
savage won't start is it dead classic xl Monster Trucks 12 08-27-2005 09:40 PM
Can't start new Savage 25 silacomalley Monster Trucks 7 08-02-2005 09:28 AM
