Old 02-16-2009, 02:41 AM   #1
Default Mini Inferno 09 needle adjust
Hi:
I've just bought it (sirio 09 engine, 16% fuel) and need some opinions about adjusting the carburator: I have the mix needle at 3 entire laps from its close position, as the manual says. Its the minimum configuration that they recomend but with this adjust the nitro engine just isn't hot, it has no power and the fuel tank gets empty in about the half of full estimated time.
I have the gas trimmed a bit because if I put it neutral the engine stops, and the carburator opening seems to be correct at that position.
The idle needle its fully closed, and even in that position the engine stops if i press the gas to reverse (brake position).
Should I adjust the mix needle until the engine gets hot and releases power, without taking care of manual?
thanks
libelula is offline   Reply With Quote
Old 02-16-2009, 07:15 AM   #2
I have a couple of these cars and have a hard time keeping them running for long as they do seem to get hot enough. I just bought some new glow plugs (hot) for them, hopefully that will help.
Evolrider is offline   Reply With Quote
Old 02-16-2009, 10:07 AM   #3
Marcus Falconie's Avatar
Default 30
Run 30% nitro, it wont hurt it I have over a gallon of 30 in the motor and it is just starting to run real good. The motor has only one needle and the drive line is so tight it wont let the motor over rev. Just hold the car off the ground and rev and lean until it hits full power and then richen 1 hour. It works for this motor but I am not recommending you try it on other motors.
www.youtube.com/watch?v=CJkwxk4hjcY
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 02-16-2009, 11:33 AM   #4
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I have run mine on 20% & 25%. I think the 16% is too low IMO, even though its a small engine.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-16-2009, 01:09 PM   #5
ok, ive just bought 20%. Ill adjust more the needle and try to hot the engine a bit more
