Old 02-13-2009, 06:48 PM   #1
Default Problem w/my new picco .12 and GT2
Anyone using the .12 picco in their GT2. the shaft size for the picco is 6mm vs. 7-8mm on the stock AE.15. It looks like Picco tried to make up for the smaller shaft by putting a really thick collet with it. In fact its to thick to work with the flywheel that comes with the GT2. Anyone know the answer for this?
I've though of a work-around. I could just grind the Picco collet down. that might work. but aside from ordering a bunch of collets online, im stuck.
thank you.
Eppidemic is offline   Reply With Quote
Old 02-13-2009, 07:17 PM   #2
kdub's Avatar
Usually there is an option collett in the box to put on the engine. Maybe try this one?
http://www.amainhobbies.com/product_...ducts_id/16944
Picco is kinda wacky.... If the angle matches up with the kit collett, then you can just grind it shorter. If the angles don't match....then you've got trouble.
I would also call Orion for help on parts because they used to use Picco based .12 engines.
kdub is offline   Reply With Quote
