Old 02-17-2009, 12:16 PM   #31
Trader Rating: 30 (100%+)
Originally Posted by markr04 View Post
Update #2:
I took it to the track and borrowed the shop's heat gun. It eventually started!
I let it idle two tanks and put the heat gun to it to keep it around 200f, while running it very rich. Then I ran it about 1/2 tank slowly around the track in my new 8ight-T, spewing smoke. It was running 165f, so I put some foil on it. Then I leaned it just a bit, still smoking the place up and burning my eyes and nose with fumes, and ran it slow again.
It's got about 3 tanks on it now. I'm going to take it to the track again tomorrow and break it in some more.
I'm thrilled as a pig in poo that it started up. Even running very rich, I can tell there's a pooload of power waiting to come out.
dont be surprised if you have to heat gun that motor to get it to start for the first time at the track every time you go until about 1 gallon goes through it it is normal just make sure that instead of driving it more you let it idle a few more tanks through it make sure the temp is 200 plus or your waisting time and it should get about 9 tanks through it at idle with good temp due to tight pinch same thing you should do with nova motors. it will last longet if you treat it right at the start mine has 10 gallons on it and still has pinch and 9 min run times
jewn_beef is offline   Reply With Quote
Old 02-17-2009, 02:25 PM   #32
PIMP_9000's Avatar
Default heat gun
+1 on the heat gun I have had to heat gun some of my engines at the track usually I do it just to ensure the break in of the engine is proper. Heating it up gets the parts to proper op temp and puts less strain on the con rod when you start it up which give you durability and longevity on your new mill. Good luck and be paitent, a well seated in engine is a happy engine?
PIMP_9000 Darrin Hunt see my paint work in painting forum keyword pimp_9000
BCG Industries/Hunt Motorsports/Outlaw Garage
Losi 8ight & 8t/Kyosho ultima sc/RB engines/castle electrical items
Fearfarm rc/KBRL/The Dirt/
PIMP_9000 is offline   Reply With Quote
