Old 02-12-2009, 05:53 PM   #1
slaytanic's Avatar
Trader Rating: 20 (95%+)
Default Ofna Truggy box help
I need some advice. My truggy bow seems to have become gutless. When I engage it, it seems to spool up alot slower than others I've seen. I thought it was my batteries but it isn't. I have trouble starting my engine with it and it is pissing me off. I know these things are beast but mine seems to have lost it's fangs. Any advice?
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 02-12-2009, 05:57 PM   #2
Trader Rating: 36 (100%+)
Could be possible you burnt out the motors? What are you using for power?
Are you still using the stock connectors? Maybe one of the motor wires came unsoldered? A few things to think about. When I first got mine, I soldered everything...even the connectors on the switch. Also, all my connectors are now Deans.
NitroOB4You is offline   Reply With Quote
Old 02-12-2009, 06:00 PM   #3
Jaz240's Avatar
Trader Rating: 52 (100%+)
Lipo? Gel? or Stick Pack? Did you change out the clips to deans plugs?
How old is the Box?
This is what I've seen...1 motor was not working due to bad wire, so box was running off 1 motor instead of 2..
Also saw 1 motor fried, had to be replaced...Feel the motors after running if one is cold and one is hot, 1 motor good and 1 motor shot..No extra charge for the rhyming
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 02-12-2009, 06:07 PM   #4
slaytanic's Avatar
Box is 100% stock. I thought about buying 2 mabuchi motors to throw in it. Which actually is what I think they use anyway. Just rebranded. And the mabuchi's are only 10$. So maybe a rewire is in order? Never done too much soldering. I guess it would be best to go to 12awg wire and deans.
I am using 2 4200 stick pack. Bought new and ONLY used in the box. Cycled maybe 10 times.
Oh, and jaz..................ICE ICE BABY!
Team Epic
Old 02-12-2009, 06:11 PM   #5
You're going to MotoRama right? If so, look for me. Ask around for Oompa (Rob)...eventually someone will likely know me. Or see the pic in my avatar...kinda small, but it should help some. Anyway, I can solder up for ya. Sat would probably be best...but I should have free time on Fri as well. I'm only running one class, Int. Truggy. Motors...EMaxx, a little more expensive, but absolutely rock solid in a box
Old 02-12-2009, 06:15 PM   #6
Jaz240's Avatar
Its also possible one your sticks are bad...try a buddies gel cell, the box has the clip for it..See if it kicks it up..There's a few things you can try..
I use a $20 gel cell and my box can rip the metal teeth off the flywheel
Old 02-12-2009, 06:15 PM   #7
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
This is a long shot, but check the tensioner. It's plastic and I somehow managed to melt it down. It finally got to a point where I noticed the box was turning into a dog. I replaced it with a couple old 5x10 bearings and it woke up again.
Also, if you've messed with the belt tension, you may have set the belt tension too tight.
K_B is offline   Reply With Quote
Old 02-12-2009, 06:22 PM   #8
slaytanic's Avatar
[QUOTE=K_B;5424568]This is a long shot, but check the tensioner. It's plastic and I somehow managed to melt it down. It finally got to a point where I noticed the box was turning into a dog. I replaced it with a couple old 5x10 bearings and it woke up again.
Also, if you've messed with the belt tension, you may have set the belt tension too tight.[/QUOTE/]
I thought it might be the belt tension but no. I checked it. I'll check the tensioner.
Team Epic
Old 02-12-2009, 09:04 PM   #9
Integra's Avatar
hrmm....so the Infamous Truggy box has motor issue's as well.......Interesting.
Old 02-12-2009, 09:59 PM   #10
K_B
K_B's Avatar
I was thinking the same thing
Old 02-13-2009, 03:25 AM   #11
slaytanic's Avatar
I've also noticed that when I depress the lid and the box winds up that the lid actually rubs the belt. I wonder if I can adjust that.
Team Epic
Old 02-13-2009, 04:13 AM   #12
qaiz's Avatar
Check the metal contact. Look at the area that houses the springs. Then press down on that entire housing, and look at the metal contact, mine did the same thing, it turned out that the metal connecter had melted into the plastic, just 4 screws, and an Xacto Knife to remove the melted plastic off the metal connector, and she was as good as new.
Mines going on for nearly a year, and is still going extremely strong...
Jammin's X2's, B + T
JP Eagle Racing Engines
Byron's Racing Fuels
Spektrum's DX3R
JR's Servos
Support your LHS.!
www.emirateshobbies.com ( Still under construction )
qaiz is offline   Reply With Quote
Old 02-13-2009, 04:33 AM   #13
Trader Rating: 47 (100%+)
Re-wire it using a 30 amp relay and some Deans connectors
for the batterys. Clean up the metal bump contacts on the
bump switch area. You will no longer be passing the load
through the bump contacts or the switch. You will never
burn up any contacts or connectors again and the motors
will last much longer.
rageworks is offline   Reply With Quote
Old 02-13-2009, 05:51 AM   #14
Integra's Avatar
Old 02-13-2009, 06:15 AM   #15
qaiz's Avatar
Also, screw those lil' tabs, Solder everything.
Spektrum's DX3R
JR's Servos
Support your LHS.!
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
8ight starter box Jonro Nitro Off-Road 69 03-19-2009 06:44 AM
Having a blast breaking in this Novarossi :( rcrevolution Nitro Off-Road 55 06-18-2008 06:49 PM
New to RC, need opinions/help. SilverScream Electric Off-Road 15 07-25-2006 10:41 PM
