Need a new clutch-what should i choose?
I need a new clutch for my kyosho inferno US sports and OS rg! the OS has a ordenary pilot SG shaft!
Which one should i choose?
I'm not a racer, just a backyard basher. So i need a cheap and good clutch!
One reccomendation would be the Fioroni Turbo Sliding clutch. The initial cost is high, but in the long run will save you alot of money from having to consistently replacing shoes and springs. The shoes on the Fioroni Turbo Sliding clutch can go for gallons and gallons before having to be replaced.
YASP - Yet Another Shameless Plug!
Good
http://answer-rcusa.com/zencart/inde...&products_id=4
Cheap
Coupon Name :: rctech
Coupon Amount :: 20%
Start Date :: 10/24/2008
End Date :: 10/24/2009
Uses per Coupon :: Unlimited
Uses per Customer :: 1
Valid Categories List :: Restrictions Apply - No MaxAmps
Cheap
M2C is my vote
Rmv Speed 2.5?
The werks 4 shoe clutch is awsome and lasts for ever. And they give you 3 types of shoes which are a good tuning option. But you are just bashing I think you said so I say just get a few sets of springs and shoes from Kyosho carbons or teflons they are cheap and wear well. I know quite a few racers that use their .9 springs and either of the 2 shoes I said.
Good
Cheap
Cheap
Good
Cheap
Cheap
I just installed the M2C clutch setup (complete package with flywheel, shoes, multiple spring weights, etc) and it is really nice. The way that Mitch has the springs in place keeps them from wearing through the shoes too. Too early for me to say how long they last but I've heard they are one of the best in that category too.
You wont be disappointed....and the adjust ability is Infinity almost....no other clutch compares Imo...The Only down side to Mitch's 4 shoe is that he has not come out with a composite shoe for even more tuning.
If your only bashing, then why does it matter what clutch you run? Go to the lhs and have them put one together for you. Simple as that........
Multiple gallon's...i use Med lite's and hard lite's....sometime's ill throw in a med ultralite...but most i stick with 4 common shoes....as i dont like to mix and match wear characteristics and have to worry about which shoes have so much time on them n such.
