Old 02-11-2009, 01:03 PM   #1
Default How create more forward traction
Hello,
How can i generate more forward traction?
Kind regards
cube1984 is offline   Reply With Quote
Old 02-11-2009, 01:20 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
better tires, better throttle finger
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 02-11-2009, 01:25 PM   #3
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Trade in your buggy for a truggy!
Ok, serious answer:
Yes, tires and throttle finger are huge items.
Lighter clutch springs (engage at lower RPM so it doesn't "hit" as hard.)
Carbon shoes instead of aluminum (slip a bit more on engagement)
Go up a tooth on the clutchbell (higher gearing means less torque applied to the wheels.)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 02-11-2009, 01:36 PM   #4
baruke1's Avatar
Trader Rating: 17 (95%+)
Longer Rear Camber Link, More Rear Toe In & I think more anti squat might help also.
baruke1 is offline   Reply With Quote
Old 02-11-2009, 02:00 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
Stiffer front suspension will also help...
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 02-11-2009, 02:11 PM   #6
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Tires and center diff affect your forward traction. Higher center diff oil will accelerate harder out of corners and straights, but give up some turning in and cornering off power. Always watch for wheel spin. Too much throttle or incorrect/crappy tires will does this, and of course, surface is the other factor.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-11-2009, 02:30 PM   #7
Thx for all your reply's
Old 02-11-2009, 03:23 PM   #8
Madbrad's Avatar
Trader Rating: 29 (100%+)
I think itthe other way around, isnt it? Carbon is softer so wouldnt it grab more.
Madbrad is offline   Reply With Quote
Old 02-11-2009, 03:29 PM   #9
jrwoodchuck's Avatar
nope, carbon grabs easer. i went to carbon for this reason.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 02-11-2009, 03:30 PM   #10
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Originally Posted by cube1984 View Post
Hello,
Kind regards
More anti squat, stand your shocks up more, lighter shock oil & springs, lighter diff oils, carbon shoes and springs.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 02-11-2009, 04:13 PM   #11
Scott Kerkes's Avatar
Trader Rating: 83 (99%+)
Hello,
Kind regards
I think Panther tires offer good forward traction because of the weaker sidewall you get the dragster traction the tire folds a bit getting a bigger footprint. The sacrifice of the weak sidewall not good for cornering. I now use AKAs firm sidewall and foams will get you around the corner faster.
Or an OS Speed will do the trick.
Scott Kerkes is offline   Reply With Quote
Old 02-11-2009, 06:14 PM   #12
jk1152's Avatar
No one talked about front Droop.
If you increase your front droop (more up & down arm movement) then when you accelerate more weight is transferred to the rear to help forward traction.
jk1152 is offline   Reply With Quote
Old 02-11-2009, 06:40 PM   #13
I think the questions need to be awnsered first.Where do yo want more forward traction? from the front or rear? On the straight or exiting corners? Do you want the car to snap straight when you whack the throttle or simply pull harder but follow the same arc.I know it sounds odd to ask but your not asking about traction going into corners are you? I know what forward traction means to me,but my mind may not think just like yours. First thing to reallize is a car with the right tires only has a certian amount of total traction & all you can do is move the traction around the car giving up some here to get more there. When you know where & when you want traction its as simple as reading the BIBLE(rc bible) & heres your link to it. Print,memorize & always have it with your car AT ALL TIMES.
http://www.teamxray.com/teamxray/pro...ria=0&catName=
HUDY off road buggy & truggy setup book/BIBLE.
butch man is offline   Reply With Quote
Old 02-11-2009, 08:11 PM   #14
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
Increasing front droop will allow more weight to transfer to the rear tires when you accelarate improving foward traction. Moving the rear hubs foward will also put more weight on the rear tires improving rear traction. Heavier center diff fluid will also help foward traction but can make the car harder to drive.
Tires come first. Make sure you are running the right tires before anything else.
infanterene is offline   Reply With Quote
Old 02-11-2009, 08:23 PM   #15
ezveedub's Avatar
I agree with tires. Adjusting droop and rear hubs will increase front to rear weight bias, so what you gain in one area, you loose in another. Same for the center diff.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
General Setup info skypilot Northwest Racers 59 12-10-2012 05:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
Sanding rubber tire ep10 Electric On-Road 20 07-23-2009 03:28 AM
