Old 02-12-2009, 05:00 AM   #16
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
So you have a lot of suggestions to play with now... but if you answer the post by Butch Man... AND tell us what car/motor/pipe/clutch/setup you are running, we can give you some specific tips. (When I say setup, I mean toe, camber, diff fluids, shock fluids, springs, camber link locations, droop, everything.)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 02-12-2009, 08:03 AM   #17
gameholic2's Avatar
Before playing with diff oils etc just try the tires in your box i was amazed at the difference in forward traction between the Losi GRP atomics i usually run and the XBT tires that came with my 2.0 kit the tires hooked up hard on corner exits and launched the car forward this extra grip make the car a lot less stable in the rough sections and the tires seemed to have less side grip in the corners but i'm sure i can get them to work with some camber adjustments.
Less toe on the wheels usualy yields better forward performance from the tires more anti squat as well but you usually give up some stability on rough parts of the track.
gameholic2 is offline   Reply With Quote
Old 02-12-2009, 08:31 AM   #18
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
More anti-squat would be the most noticeable gain.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 02-12-2009, 02:17 PM   #19
Trader Rating: 19 (100%+)
Default Traction
I think the best change for traction is moving the the rear hubs forward.
Jmnay_83 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
General Setup info skypilot Northwest Racers 59 12-10-2012 05:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
Sanding rubber tire ep10 Electric On-Road 20 07-23-2009 03:28 AM
