Old 02-11-2009, 01:02 PM   #1
JEB21's Avatar
Default Losi 8ight question
Got a great deal on the 8ight with the new 2.0 out. I'm sure there is an 8 thread around somewhere but I had a quick question for all you guys driving one of these buggys.
Are there any hop-ups I should do immediately right out of the box?
I've heard great things about this kit but would love to address any problem areas during the build. Thanks guys!
JEB21 is offline   Reply With Quote
Old 02-11-2009, 01:36 PM   #2
tc5 man's Avatar
well with the eight kit i got one when there $300 i still building it the bushings that go into to the steering rack are fairy tight to get in.when you build the diffs look to see if there is any burrs around them ,i got the burrs off but they still dont feel that smooth i grabs a bit but i think when i run the buggy they will be smooth and make sure all the brake/throttle rods have threads on them cause i had one with no threads and i had to call horizon to get them in the mail. there is a thread for the eight
Old 02-11-2009, 01:40 PM   #3
JEB21's Avatar
Thanks, you have a link for the "official" 8ight thread? keep me posted on your build.
Old 02-11-2009, 01:41 PM   #4
BAUSTIN's Avatar
i would use the 2.0 outer rear hinge pins, you will have to ream out the a-arms
i would get the 2.0 radio tray and linkage
and i would get a truggy spring for your servo saver....
...you dont need any aluminum.....the car works great out of the box......
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 02-11-2009, 01:42 PM   #5
Akhor's Avatar
You will probably want to add the aftermarket King Headz radio tray stiffener to your 1.0 kit. It will possibly save you burning up servo's.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 02-11-2009, 01:48 PM   #6
BAUSTIN's Avatar
if you get this you wont need the 2.0 radio tray......
Billy Austin
www.Code3RC.com
Elevation Sports
Old 02-11-2009, 02:36 PM   #7
JEB21's Avatar
I heard the aluminum servo arm is a must as well?
I've got a couple NIB Hitec 5645 servos lying around from a plane build that never happened. These have enough umphhh for an 1/8 scale buggy?
Digital hi-torque metal geared
Speed: 0.18 sec/60 at 6.0V
Torque: 164.2 oz-in at 6V
Thanks for all the info so far.
Old 02-11-2009, 03:00 PM   #8
Fletcher6371's Avatar
Yeah those are good to start with, I won a sportsman race with those servos, but a 7955tg is AWSOME for steering. (I wouldn't get new servos till one blows up)
CRC "no-pop" steering balls
Alum. Servo horn
Rear Gear box inserts
King heads Radio Tray stiffener
Extended Engine Mount (not needed but makes life a lot easier)
Just my recommendations to the 8ight 1.0. But even if you don't get these parts its still a great and competitive buggy out of the box!
FlatBusted Racing
Dialed Inc., North Central Hobbies, Competition Heat, FUnS Racing lol
Fletcher6371 is offline   Reply With Quote
Old 02-11-2009, 03:26 PM   #9
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I would do like some have already said. 2.0 rear outer hinge pins, or the m2c racing pin set. KHZ radio tray stiffner or a 2.0 radio tray and linkage. Also either the crc non pop steering balls, or the mod I did, which is the same thing the 2.0 runs. You just need a set of losi steering balls and some 5-40x3/4" countersunk screws. You use the inner(non threaded) balls and the screws. this will keep the ball ends on. Never had one pop since doing this mod 2 years ago. Actually I still have the same plastic ball ends on and there is no slop and none have popped off. I would also reccomend losi or GMK supply CVD condoms to keep the center drive pins in. And like you said the losi aluminum steering servo horn is a must(or any other aluminum horn).
http://www.amainhobbies.com/product_...oducts_id/7756
http://www.amainhobbies.com/product_...oducts_id/7767
http://www.amainhobbies.com/product_...ducts_id/30442
http://www.amainhobbies.com/product_...ducts_id/16263
http://www.amainhobbies.com/product_...ducts_id/25150
http://www.amainhobbies.com/product_...ducts_id/13168
http://www.amainhobbies.com/product_...ducts_id/30460
http://www.amainhobbies.com/product_...ducts_id/11534
http://www.amainhobbies.com/product_...ducts_id/30434
http://www.amainhobbies.com/product_...ducts_id/30452
Lots of different ways to go. hence all the links
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 02-11-2009, 03:55 PM   #10
screamin' eagle's Avatar
Build what you got and run it first. Worry about hop-ups later. You're getting way ahead of yourself.
Hyper 7 PBS Converted To Brushless/MMM 2650kv
screamin' eagle is offline   Reply With Quote
Old 02-11-2009, 04:00 PM   #11
good point eagle, run what you got and see what you break/wear out/ or if you need to upgrade. A lot of things i have are because i broke them (but others haven't sooomaybe i just suck as a driver LOL) but really build what you got and upgrade as you go along.
FlatBusted Racing
Old 02-11-2009, 04:01 PM   #12
JEB21's Avatar
Since when have you ever known me to do that? Boy is that the pot calling the kettle black by the way.
Old 02-11-2009, 04:04 PM   #13
JEB21's Avatar
It's not really hopups I was looking for per say. More like any known weak spots I should deal with now.
Old 02-11-2009, 04:09 PM   #14
My purpose is for you to learn from my mistakes, not repeat them.
Old 02-11-2009, 04:26 PM   #15
JEB21's Avatar
now your taking all the fun out of it...
8ight - GoTech .21 5 port
Kyosho RB5 - Novak 10.5
Vendetta ST - Ammo 3900
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
RC8 RTR vs Losi 8ight RTR vs Jammin X1 RTR sidewaze Nitro Off-Road 30 12-30-2008 06:23 AM
Kyosho MP9 compared to Hot Bodies D8 xpertpredator Nitro Off-Road 121 12-23-2008 02:33 PM
Mugen MBX5T or losi 8ight t playboy Nitro Off-Road 54 03-06-2008 03:16 PM
RTR 8ight Fuel choice? JeffEmbracedDC Nitro Off-Road 9 11-21-2007 08:25 AM
8th Buggy Opinions scoobydo Electric Off-Road 15 03-05-2007 03:53 PM
