Old 02-11-2009, 10:04 AM   #1
Gixxer2k4's Avatar
Send a message via AIM to Gixxer2k4
Default xray 809?
Was gonna get an 808 an amain was out of em so i asked when they would recieve more. Was told they are discontinued by xray an the 809 was going to be released. Has anyone heard this?
Gixxer2k4 is offline   Reply With Quote
Old 02-11-2009, 10:08 AM   #2
esridge's Avatar
Trader Rating: 10 (92%+)
http://www.teamxray.com/teamxray/new...1fbe835290ef64
www.tilted1.com , www.tiltedrc.com , Tilted Fuel , Team Terribles
esridge is offline   Reply With Quote
Old 02-11-2009, 10:08 AM   #3
slaytanic's Avatar
Trader Rating: 20 (95%+)
No new buggy. They are just releasing the 808 with 2009 specs. Not alot of big changes and should allow you to get a great deal on an 808 right now if you find one.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 02-11-2009, 10:09 AM   #4
imaxx21's Avatar
Send a message via AIM to imaxx21
http://www.neobuggy.net/modules/news...p?storyid=5574
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 02-11-2009, 11:25 AM   #5
Akhor's Avatar
I think X-Ray releases a new upgrade to all their vehicle lines once a year... At least that's what it feels like.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 02-11-2009, 11:58 AM   #6
Its the same buggy with a few small mechanical upgrades that improve durability, and improve maintenance cycles. Basically this buggy was solid before, but now its bullet proof!
Here is the info:
Based on the successful 808 platform, the new 2009-spec XB808 was updated with a focus on improving tiny details to make a tougher, lighter, and more durable top-competitive nitro buggy. With the legendary Dipl. Ing. Juraj Hudy leading the XRAY design team, the new XB808 benefits in every possible way. Knowing that upgrades of small details give big overall effects on performance, the 2009-spec XB808 is a perfect example of legendary XRAY craftsmanship. Stronger yet lighter components, smarter assemblies and designs… all with the idea of making the XB808 easier to drive & maintain, while still being ahead of the competition on the track and on the podium.
2009 XRAY 808 New Specs:
• new ultra-low profile racing body, designed exclusively by XRAY
• new super-low profile foam air filter with redesigned rubber elbow
• new stronger, one-side steel-sealed diff ball-bearings
• new alu bearing collar reinforces diff bearing assemblies
• new reinforced composite front & rear bulkheads
• new larger capacity fuel tank with capacity-adjustment segments
• new fuel line holders mounted directly on fuel tank
• new fuel tank pressure cap with 1-piece profiled seal for perfect fitment
• new reinforced composite ball joints
• new protective rubber folding shock boots for big-bore shocks, front & rear
• new lower shock body mounting cap, grooved for folding shock boots
• new narrow lower shock ball joints, redesigned for folding shock boots
• new upgraded servo saver with O-ring for secure adjustment
• new longer rear shock body mount for more secure body mounting
XRAY 808 Specs:
• premium high-competition off-road buggy
• efficient Zero King-pin suspension
• lightweight strong molded steering blocks with molded-in steel bushings
• ultra-low CG, all parts centralized in chassis
• optimized front/rear and left/right weight balance for perfect jumping
• pure racing design, highest performance and long life, ultra-durable parts
• fully independent, fully-adjustable suspension with full-time 4WD
• ultra-lightweight high-tensile transmission parts hand made from special world-renowned top-secret self-developed HUDY Spring Steel™
Drivetrain includes 22 high-speed rubber-sealed bearings for maximum efficiency and speed
• ultra-precision front/rear and center diffs with HUDY Spring Steel™ outdrives
• pinions, spurs, crown gears and clutchbell manufactured by HUDY
• optimized multiple upper and lower shock mounting locations for front and rear
• laser-cut, precision-ground steel brake disks for ultra-efficient fade-free braking
• high-grip Ferodoฎ brake pads
• exclusive adjustable turnbuckles from HUDY Spring Steel™
• tiny steering blocks with molded-in steel bushings and new caster blocks
• flexible suspension holders with integrated preset optimal suspension geometry
• high tensile Swiss 7075 T6 hard anodized chassis
• ultra-strong suspension pivot pins inboard and outboard
• Direct Shaft Connection™ to the pinion gear
• anti-roll bars
• HUDY Spring Steel™ turnbuckles
• centralized engine positioning
• narrow servo saver and steering system
• ultra-short graphite steering plate
• one-piece graphite radio plate
• front & rear flexible composite brace
• gear boxes with Labyrinth Dust Covers™
• clutch bell with over-sized clutch bearings
• 4mm extra-thick front and 3.5mm rear premium-grade graphite shock towers
• big-bore oversized shocks for excellent handling on bumpy tracks and big jumps
• threaded big-bore hard-anodized shock bodies
• XRAY Premium Shock Oils for perfect consistency
• A winner’s pedigree & DNA – countless National and Championship titles, Multiple Car-of-the-Year awards
New 808 "09 Body looks much better...
CarCrazy is offline   Reply With Quote
Old 02-11-2009, 12:03 PM   #7
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Here is the info:
XRAY 808 Specs:
• anti-roll bars
SO basically another losi copy. Gotta have a low profile body cuz losi does. Xray makes me laugh I mean I like thier cars and think they are very nice but damn enough losi copies. Next thing will be the losi 8T 2.0 copied into the xray 808ight T.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 02-11-2009, 12:05 PM   #8
Gixxer2k4's Avatar
whats its release date?
Old 02-11-2009, 12:06 PM   #9
Integra's Avatar
I concur.
Old 02-11-2009, 12:08 PM   #10
Originally Posted by Integra View Post
I concur.
-Koby Kubrin-
Old 02-11-2009, 12:43 PM   #11
Akhor's Avatar
I concur.
+1
--Blaine--
VBC D07, VBC D08
Old 02-11-2009, 12:50 PM   #12
Trader Rating: 19 (100%+)
Nothing wrong with taking something and making it better. Losi had a good design. Xray just improved on it and the materials.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 02-11-2009, 02:17 PM   #13
rmargiotta's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to rmargiotta
I concur.
Originally Posted by Akhor View Post
+1
Ignorance MUST be bliss.........or contagious, I'm not sure... haha
All I have to say on this matter (which happens to not be subjective like the posts above): please look at any thread/forum on the topic of what the customers would like to see change on the 808, you will find that most asked for the changes that have been made for this year's model.
Sponsors:
- Cold Hard-Earned Cash Money -
rmargiotta is offline   Reply With Quote
Old 02-11-2009, 02:23 PM   #14
Just for the small details. In Europe
Losi 2.0 499 € Made in Taiwan
Xray 808 2009 spec 499 € Made In Slovakia (still more expensive than china)
Don't blame people to buy an xray, if you can get the same performance and better quality for the same price. At least here it's an obvious choice..
Mister-T is offline   Reply With Quote
Old 02-11-2009, 02:45 PM   #15
slaytanic's Avatar
Well said.
The only thing I wish the 808 came with is a set of plastic rear blocks like mugen did.
Team Epic
Batam RC Kopitiam batamrc Indonesia Racing 3502 07-28-2015 12:14 AM
RC Connections ( Glenmarie ) -Onroad, Offroad, Drift & Crawlers TRACK alvinL Malaysian R/C Racers 979 08-25-2011 11:02 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
MBX-6 - Xray 808 - MP9 - Best buy? Best Quality? Alffa164 Nitro Off-Road 84 02-18-2009 07:29 AM
2008 IFMAR 1/10 200mm On-Road World Championships: Aug 7-17 bvoltz Nitro On-Road 1317 08-27-2008 10:57 AM
2008 AARCMCC 1/8th IC Off Road National Titles.. MadRacer Australian Racing 45 04-30-2008 02:11 PM
