Old 02-11-2009, 05:48 AM   #1
Default How you clean your rides?
I'm wondering, how you clean your rides?
Personally, I remove electronics and engine, spray simple green, wait few minute and use a toothbrush to remove extra dirt and use a compressor to finish.
After all this, I spray WD40 everywhere and blow extra liquid with air compressor.
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 02-11-2009, 06:02 AM   #2
PTP Racing's Avatar
Thats pretty much the standard way to do it.
I always try not to use anything water based on my car anymore. My last car never saw water. I ran it in some seriously muddy conditions but never enough to get it wet. I cleaned it frequently at the track with compressed air and afterwards with wd-40 and a brush.
I found out about Maxima SC1 at the end of the year. Its a silicone type spray used by MotoX guys to keep their bikes clean. It shines everything up nice and the dirt doesnt stick to it so the car stays cleaner and the dirt blows off easier. I used to walk by a local fast guys pit and wonder how he could run 2 or 3 classes at a race and still keep all his stuff immaculate and it was because he was using it on everything and I mean everything from his pit board to the buggy. I bought a couple cans of it and I am going to try and use it exclusively on my new buggy. It says its 100% safe for everything in our cars I was only told to avoid spraying the air filter for obvious reasons. Its a really fine spray so it seems like a can will last a really long time and it smells good so when I use it at home the family likes it vs most of the stuff I use when they all go running for cover.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 02-11-2009, 06:12 AM   #3
l3asher's Avatar
Water and a hose the I blow it off and wd 40 it.
l3asher is offline   Reply With Quote
Old 02-11-2009, 06:25 AM   #4
Akhor's Avatar
1) Simple Green
2) Hot Water
3) Compressor Dry
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 02-11-2009, 06:26 AM   #5
wallot's Avatar
engine and electronics off then shower with mild detergent to get the grease of.
dry with compressor, spray with PTFE.
got stainless bearings so they dont have problems with water, but always check them and replace when needed.
or just nitro spray with upgrade/rc brushes if I am lazy as it will get dirty next weekend anyway
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 02-11-2009, 06:30 AM   #6
shipwama's Avatar
For a different way to keep your car clean, when i used to race dirt sprint cars, a little trick we used was to mix 1 part wd 40 with 1 part baby oil, kept the dirt off the cars amazingly, i loved this trick after i found it out, made cleaning a lot easier!!
shipwama is offline   Reply With Quote
Old 02-11-2009, 06:44 AM   #7
Send a message via MSN to xtopher_aaron
Just a question tho.. Is WD40 actually safe? What if it gets into the electronics? like your servo's and rx's ?
secondly, do you spray it on after or before you clean?
finally, doesnt WD40 keep your car oily and greasy ?
I run nitro if it helps..
As for my tips, so far its been a toothbrush, a regular painting brush, and the compressor air gun. I only use WD40 on thing like my exhaust and stuff that are shiny.. Soap and water are all i use for things like bodies, wheels and stuff..
Another things is, I worry about stripping my car down too much, im afraid that the screws that go into plastic parts might get loose soon.. Any tips for that?
Mugen Seiki MTX-4R || LRP Z.12R Spec 4 || LRP Pipes || Spektrum DX3R (Coming Soon) ||
xtopher_aaron is offline   Reply With Quote
Old 02-11-2009, 07:50 AM   #8
remove tray and motorand tank, then its gets a hose down outside, then a blow off with air, then wd40 and another blow off. walla its new again!
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
Old 02-11-2009, 08:06 AM   #9
yaright's Avatar
Remove tray, motor and fuel tank. Stick in dish washer.LOL
Whaen the wife finds out... run for cover
Losi 8ight T 2.0.....PRO TWISTER MODS GO 25 6 Port / GRP
DX3R JR 9100t & 8800t
J-DUB HUBZ
Losi 8ight.....Dynamite Platinum 21XP..........JR8800T's
www.trackseekers.com
yaright is offline   Reply With Quote
Old 02-11-2009, 08:08 AM   #10
fatdaddy's Avatar
WD40 is perfectly fine for your car. sounds like you kinda got everything backwards. don't use wd40 on your exhaust. it leaves an oily film on there that is going to have to burn off every time put wd40 on it. i dont put wd40 anywhere on my engine or my electronics. WD40 is also OK for your tires and bodies. soap and water is also perfectly acceptable.
to clean my reciever case and servo tray without removing everything from it. just spray some wd40 on a toothbrush, then you can brush on the wd40 just where you want it, and not spraying a big mess all over with the can.
the engine i just clean with a dry toothbrush or paint brush, and really try to get behind the flywheel with the toothbrush to get some of that hidden debris out of there. don't forget to plug of any openings into the engine. if you take off the fuel like to pull the motor, i like to take a 2" piece of fuel tube, and fold the last 3/4" over on itself and secure it with a zip tie. now you have a nice fuel like block off.
the car is almost the easiest thing to clean. once you removed the electronics, and motor (i like to take out my fuel tank and clean that separately also) cover the entire car with undiluted Simple Green, wait a few minutes. wash it off with a high pressure hose, then blow dry every nook and cranny with compressed air. i try to make it as 100% dry as possible with just the compressed air. then hose the car down with WD40. head to toe. especially any U-joints, and bearings. wait 15 minutes for it to kinda soak in and penetrate. then give it a good compressed air blast again. not like before. just enough to get the excess off. take a rag and wipe the main chassis so there's not a heavy film on there. leave the rest of the plastic. it will soak in overnight. your car will look brand new again!
now as for the screws. treat plastic the same way you would metal. when you put in the screw make sure you start off twisting the screw counter clockwise to find the start of the threads in the plastic, and then start the screw gently. this should all be able to be done by hand at first. then use your tools to drive it home. not too hard though! snug it up, don't give it the death twist. and if the screw starts to come loose while you drive, don't try to tighten it down harder. put a dab of thin CA on the end of the screw. its like lock-tite for plastic. works great, and the screw still comes out easily! (when YOU want it to )
*phew* sorry for the long post
fatdaddy is offline   Reply With Quote
Old 02-11-2009, 08:53 AM   #11
Charles Godwin's Avatar
Complete rebuild. Takes effort but everything is checked for wear and replaced if needed.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is online now   Reply With Quote
Old 02-11-2009, 11:00 AM   #12
Much appreciated nonetheless.. Thank you sir..
Old 02-11-2009, 11:12 AM   #13
Madbrad's Avatar
Trader Rating: 29 (100%+)
Where can you get Maxima SC1 at ? I'd like to try that stuff out.
Madbrad is offline   Reply With Quote
Old 02-11-2009, 11:13 AM   #14
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 02-11-2009, 11:17 AM   #15
You can get Maxima SC1 at any motocross store near you.
Lutz leaves Kyosho For Tamiya! D8 Nitro Off-Road 141 01-30-2009 01:03 PM
Is my buggy still competitive? SoHotRightNow Nitro Off-Road 13 01-15-2009 09:41 PM
Losi Mini Sliders air8 Oval, Larger Scales and More 35 02-03-2008 08:00 AM
