Old 02-09-2009, 08:38 PM   #1
Default Losi 8ight Shock Rebuilding Problems
I have an 8ight rtr buggy with the plastic shock caps. I am rebuilding the shocks now. I put new white o rings in with green slime, and for some reason after I fill them up (just up to the top) and put the NEW shock bladder in, when I move the shock around, and I take it out to put more/less shock oil in the shock, there are TONS of air bubbles. Why is this? I talked to one person and he said he had never had this problem and was wondeirng if anyone else has had this problem? Ive built Losi 10th scale truck shocks all the time, but for some reason it is hard to get these shocks right.
I have the Losi Shock Balancer if this makea a difference. thanks!
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 02-09-2009, 08:51 PM   #2
l3asher's Avatar
Do you raise the piston up and down to get the air bubbles out?
I always let my sit for 5 to 10 minutes for the air bubbles to rise to the top.
l3asher is offline   Reply With Quote
Old 02-09-2009, 08:57 PM   #3
Yes I move it up and down. It is to the point where I pump it up and down, let it sit 10 minutes, still air bubbles. Pump it up and down again, wait 20 minutes, etc. Then when there is finally no air bubbles I put the shock cap on and then i have to repeat the process!
Old 02-09-2009, 09:06 PM   #4
Are you pumping up the piston so far up that it is coming out of the oil?
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 02-09-2009, 09:13 PM   #5
No.
Old 02-09-2009, 09:14 PM   #6
Like I said there is no air when I put the bladder and cap on, but there is tons of it when I take it off. Could it be the shock cap?
Old 02-09-2009, 09:18 PM   #7
BOOST's Avatar
Okay....are you filling the shock below the very top and placing the bladder on top which will trap air under the bladder? that could be where the air is coming from. I always fill to the top and let the excess bleed through the hole in the shock cap.
BOOST is offline   Reply With Quote
Old 02-09-2009, 09:19 PM   #8
Well the bladders are new, so make sure they're seated right and screw on the cap tight if all else fails get the aluminum caps.
Old 02-09-2009, 09:22 PM   #9
I will try that. I guess I can always bleed rather than add more oil. I will tell you how it works!
Old 02-10-2009, 05:37 AM   #10
That's the right way to build them. Fill to the top, then place the bladder into the shock body and press it down lightly. Then screw the cap on and check the compression, bleed more off if you want. Most people run the 8ight with full rebound on the shocks.
cjtamu is offline   Reply With Quote
Old 02-10-2009, 05:49 AM   #11
Suspended
Trader Rating: 440 (99%+)
So most people use full rebound? I have been running mine with very minimal rebound for a while now. I wonder how running more rebound would affect the car?
Am I right by thinking that on smoother tracks less rebound would be better and on bumpy tracks more rebound would be better?
MattP is offline   Reply With Quote
Old 02-10-2009, 06:03 AM   #12
I would think the opposite would be true. Stiffer shock for a smoother surface.
John Schafer is offline   Reply With Quote
Old 02-10-2009, 09:14 AM   #13
I like the feel better with full rebound, it lets me run a little less spring preload to get the ride height I want. I started doing it last year when I saw a post from Truhe about building the shocks that way. But WTF does he know about it? LOL.
Old 02-10-2009, 12:15 PM   #14
cornerspeed's Avatar
There is a cool way of getting the air bubbles out of the shock. Fill with oil with the piston all the way down. Raise up the piston WITHOUT pulling it down at all, SLOWLY, til it gets near the top. Then twist and pull down the piston slowly up and down near the top. This will pull the air bubbles up to the top and have larger bubbles. This will clear the bubbles out faster and not creat those tiny bubbles that take so long to disappate.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 02-10-2009, 12:40 PM   #15
Akhor's Avatar
Great idea!
I'm going to try this next time I'm shock building.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
