Old 02-09-2009, 07:42 AM   #1
TRIPC's Avatar
Default Mugen clutch set up in a Losi 8
I was at my LHS shop yesterday talking to the guy about my clutch set up. I am running the Losi 4 shoe 2 alum-2 comp. And I think it works pretty good. Im always open to new ideas tho. He said the Mugen 3 shoe set up was alot better and easier to work on. My question is what Mugen clutch is it and where can I get more info on it??
Losi 8B OS V-Spec/Ex-Tech/Novarossi
Losi 8T OS V-Spec (in the works)!
Spektrum DX3S
TRIPC is offline   Reply With Quote
Old 02-09-2009, 07:52 AM   #2
wallot's Avatar
mugen clutch comes with mugen buggies/truggies. it's standard 3 aluminum shoe clutch.
I am not fan of aluminum shoes they need to much maintenance
also mixing aluminum and plastic shoes is nit the best idea as aluminum will leave some residue on the clutchbell that the plastic shoes will catch and it will lower their grip (unles you maintain you clutch quite often)
been fan of reckward 2.5 extened clutch in my truggy as it has bigger shoes for more grip so it does not really matter that they are not aluminum. it works nicely in my buggy but since I got the clutch shoe removal tool I will test the clutch that came with my buggy - standard 3 plastic shoe clutch.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 02-09-2009, 08:10 AM   #3
With the losi motor mount you can use just about any three shoe clutch, I have used the Assoc. with no problems. You need to move the motor forward a bit in order to use the non losi clutchs...the losi adjutable motor mount allows this. Shimming will be neede to get exactly right but not a big deal.
Thopper is offline   Reply With Quote
Old 02-10-2009, 08:11 AM   #4
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Actually when I used to run a Losi, I ran a Mugen clutch. It is MUCH easier if you have the King Headz motormount- you flip the rails one way for the Losi clutchbell, the other way for the Mugen one. The Losi clutchbell is longer. (the gear teeth stick further forward.)
It is a lot easier to find the Mugen parts, and it uses 2 bearings of the same size, the same ones virtually everyone BUT Losi uses. Since I never ran the Losi clutch I can't comment on which is better... but I DID use Losi clutchbells on the Mugen clutch setup prior to getting the King Headz motormount... I had a lot less bearing and clutchbell issues with the Mugen bell.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 02-10-2009, 08:14 AM   #5
Trader Rating: 163 (100%+)
the losi clutch is the easiest clutch to work on, what problems are you having with the stock clutch set up?
cjm1126 is offline   Reply With Quote
Old 02-10-2009, 01:46 PM   #6
TRIPC's Avatar
Its not so much that I am having problems with the Losi clutch. The guy at the LHS just recommended the Mugen. I think the Losi is pretty easy to work on. I think he was saying for the shimming purposes. The Mugen was easier.
Spektrum DX3S
Old 02-10-2009, 01:57 PM   #7
i would stick with the losi, its easy to shim, i use 1 shim behind the inner bearing to space the bell out so it dosent rub the flywheel, i just use the stock tapered bolt with the male spacer on the outside it works good
Old 04-06-2009, 12:13 PM   #8
BIG RE's Avatar
Trader Rating: 32 (100%+)
Is there a way to run a 3 shoe setup without having to buy the other engine mount? I have a Kyosho/Hot Bodies 3 shoe setup and would love to stay with it if possible.
BIG RE is offline   Reply With Quote
Old 04-06-2009, 02:24 PM   #9
RyyRyy's Avatar
Trader Rating: 16 (94%+)
The mugen clutch is by far our favorite. Been running them for years and is the only clutch I will run regardless what car... A really good setup is the carbon shoes, with 1.0mm springs. has a great feel to it!!
RyyRyy is offline   Reply With Quote
Old 04-06-2009, 02:30 PM   #10
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Losi clutch w/ Dynamite clutch shoes equate to nearly maintenance free. You'll be changing bearings once in a while, but the clutch shoes require zero attention. Even with the Dynamite clutch shoes you can play with different spring weights as a tuning option.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 04-06-2009, 03:07 PM   #11
tony montana's Avatar
Trader Rating: 65 (100%+)
the losi clutch is the biggest reason I would want to run the buggy, It is just easy to work on and gives good snap
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 04-06-2009, 03:11 PM   #12
TRIPC's Avatar
The ther day when my motor blew up I fried 2 clutch bearings. The first one was the smaller one then I replaced that one . Next my motor blew and I noticed my bigger bearing was completly torn apart. Whats up with that?? How does that happen??
Spektrum DX3S
Old 04-06-2009, 05:43 PM   #13
Steebo's Avatar
Hey, just wanted to throw the Impulse-r/c shoes out there. Three shoe AL, Associated style. $11.99
Team Associated, Factory Team, Reedy, LRP, Impulse r/c, Upgrade r/c
www.impulse-rc.com
Steebo is offline   Reply With Quote
Old 04-06-2009, 11:16 PM   #14
BIG RE's Avatar
I can't believe how many times I am having to ask this question, hopefully this time I will get an answer. Is there a 3 shoe clutch system that works without having to buy the optional motor mount?
Old 04-06-2009, 11:16 PM   #15
imaxx21's Avatar
Send a message via AIM to imaxx21
no
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
NITRO BLOWOUT SALE...JAMMIN-SPEKTRUM-LOSI-ODONNELL AND MORE stevenmichael R/C Items: For Sale/Trade 40 12-04-2008 07:08 PM
Blow Out Sale....... Factory Seal R/C Items: For Sale/Trade 20 07-03-2008 04:41 PM
Losi 8 T hopped up... rossoh10 R/C Items: For Sale/Trade 18 12-27-2007 05:02 PM
Lost 8ight/8T vs Mugen MBX5R/MBX5T brent98rt Electric Off-Road 32 05-20-2007 08:59 PM
COMPLETELY Selling OUT!! Buy my stuff.. I NEED money!!! Mustangz R/C Items: For Sale/Trade 60 01-24-2007 07:16 PM
