Old 02-08-2009, 07:42 PM   #16
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
there is only one product to use, and it is yamalube....hey ahve a sorage oil that foams, it is the best ting going...i dont have a link but i posted one on this topic a few months ago....
my motors on teardown have no corosion and excelent bearing life....
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 02-08-2009, 08:34 PM   #17
empir3's Avatar
So what does it do........
Associated rc 10.
still rollin on spin offs.
"life is hard;its harder if your stupid." (john wayne)
empir3 is offline   Reply With Quote
Old 02-08-2009, 09:05 PM   #18
mtbkym01's Avatar
I'm led to believe that the remnants of the fuel (Not sure if it's the Methanol, or Nitro) attracts moisture, promoting corrosion, therefore, coating the engine internals with oil prevents corrosion, lengthening engine component life.
Cheers
~Kym Nuske~
RCHobbyzone.com.au / Model Motorsports International
Mugen Seiki 1/8, Reds, Neo+ Fuels
AE 1/10, Reds
"If it's old skool, it's kool"
mtbkym01 is offline   Reply With Quote
Old 02-08-2009, 09:38 PM   #19
empir3's Avatar
Cheers
Thanks for that explanation! Greatly appreciated!
Associated rc 10.
Old 02-08-2009, 09:39 PM   #20
Originally Posted by layedbackguy View Post
I have seen guys use wd40, marvel oil, and one guy use that lucas oil for regular car engines. The fuel i run has enough oil so after run is not needed.
I would STRONGLY disagree. If it is nitro you are running after run is a MUST if you like your bearings and engine. After run oil displaces the water that is attracted to your engine. Plus, nitro is corrosive anyway, and it burns extremely dry. The only reason oil is in the fuel is the same reason it runs in a dirt bike, its just 2stroke. That doesnt mean that afterrun is not necessary. If it was standard unleaded gas you would be fine, but unleaded fuel is not near as aggressive as nitro. WD is perfectly fine, the 3in1 at the hardware store fine, air tool oil, fine. There is no need to pay double for a so called PURPOSE designed oil, because, well, there are already a million types on the shelf that will work. I wouldnt recommend motor oil, but just for the sake that its too thick to get between some of the tollerances in the motor.
In my opinion, its just silly not to run ARO. It only takes a second and its adds many more runs to the motor.
One added thing, i keep a can of Chemtool in my bag, before i change a plug, or pull it for ARO, i squirt a charge in there to rinse out the dirt to prevent dirt entering the motor. Turn it up side down, blast, remove plug. Works great.
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 02-09-2009, 02:55 AM   #21
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
if i'm not mistaken, the only time to use after run oil if you not going to run engine for a long period of time? or if you tear the engine down you use it as well...i hardly use after run because mostly the fuel have enough oil to keep the motor lubicated like byrons or sidewinder plus i notice if you keep doing after run maintenance it does do alittle wear on the sleeve(you put drops in the motor then cover with rag or papertowel then hold it down on the start box for 5-8 sec) IMO i don't use afterrun only when i tear down the engine for clean up
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Team Magic E4 Thread gansei Electric On-Road 4124 02-07-2017 01:09 PM
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
SC10 Thread JDCrow Electric Off-Road 12123 05-29-2012 04:40 PM
Serpent 720 rcrossco_1 Nitro On-Road 5073 04-16-2012 08:42 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
