Old 02-07-2009, 06:27 PM   #1
losiracer78's Avatar
Default Front Bearing in Nova rossi
I have a bearing in a nova rossi that gone bad after only 1/2 Gal of fuel. how hard is it to change out and what might be the cause of it. Its the Front bearing.
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 02-07-2009, 06:28 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
whats wrong with it?
some slight leakage is normal..
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 02-07-2009, 06:32 PM   #3
it leaks and will not idle right anymore so im thinking its sucking air and the temp is jumping up 30 deg. never seen a motor do this that fast . norm i would just junk it and buy a new one but with only 1/2 gal though it i dont want to do that yeah i still have a ninja that i love but thats for big races the rossi is just for club racing
Old 02-07-2009, 06:58 PM   #4
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Stripping the case and heat it up will allow you to push it out with a wood dowel. Reheat and install the new one by putting it cold from the freezer on the end of the crank nose and push it in the hot case. Let it cool off and reassemble the engine. You can use bearing press/pullers, but they cost quite a bit.
One note, it you run your engine fairly rich, it will sweat out of the front bearing, so make sure your tune is proper before condenming the bearing, unless you see actually see seal damage.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-07-2009, 07:26 PM   #5
i understand that i have been racing for years but this is my first rossi motor and not to happy it went from running really good i was really happy with it and then it started all of this. it will not idle anymore. the other thing is that the glow might be going bad now that i think about it i dont think that i have changed the glow plug in it yet its the same one that came in it might be my prob with the idle prob. where has my head been??? i guess trying to get my pro series car ready
Old 02-07-2009, 07:37 PM   #6
r1harper's Avatar
Trader Rating: 24 (100%+)
to check the front bearing is sucking air, crank it and spray carb cleaner at the front bearing and the engine should die instantly.. if not the front bearing is not your problem
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 02-07-2009, 11:43 PM   #7
Heat the case up and pop it out. get a TKO ceramic and then reheat the case. Dont cool the bearing as its to extreme of a temperature change to quick. It will slide in with the bearing at room temp.
nitrofreak32 is offline   Reply With Quote
Old 02-08-2009, 07:51 AM   #8
any more ideas out there
Old 02-08-2009, 08:14 AM   #9
houston's Avatar
Trader Rating: 91 (100%+)
you pay for shipping and bearing at cost and i will provide labor free
lmk ,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 02-08-2009, 08:52 AM   #10
i dont have a prob fixing it just wanted to make sure thats the prob before i put any money into bearings and come to find out thats not what it is do you know what i mean. The little motor has some go for sure not as much as my ninja but a good shot to med track motor.
2000 Serpent Impact Full Race set-up!!! rayhuang R/C Items: For Sale/Trade 9 05-08-2002 08:33 PM
