Old 02-06-2009, 07:26 PM   #1
hobdog's Avatar
Trader Rating: 19 (100%+)
Default a couple of OS Speed questions
How many shims are supposed to be run under the head button (I am using Byrons race 30%)? I am running the alluminum one and the copper one right now. Also I am going freshening up the mill, and am curious if anyone has run the jx ninja piston, sleeve, connecting rod in this mill with any good results. I ask because I am running it in a truggy and from what I have heard the Jx seems to be a real popular choice in truggies, and the speed is more popular in the buggies
hobdog is offline   Reply With Quote
Old 02-06-2009, 09:44 PM   #2
rpm1968's Avatar
Trader Rating: 18 (100%+)
AS PER THE MAN:
Stock shims on the V-Spec, Speed and JX-21 are (1) 0.008" (0.2mm) aluminum shim and (1) 0.004" (0.1mm) copper shim.
If you use the EB Mod head button then you use only (1) 0.004" (0.1mm) copper shim.
_________________
Tony P.
rpm1968 is offline   Reply With Quote
Old 02-07-2009, 08:20 AM   #3
hobdog's Avatar
Originally Posted by rpm1968 View Post
AS PER THE MAN:
_________________
Tony P.
Thanks Rev! Now how about the Jx piston, sleeve, and connecting rod in the speed case? Someone has to have tried it.
Old 02-07-2009, 09:02 PM   #4
hobdog's Avatar
come on now, no one has done this? I guess everyone is out racing this weekend. I believe I have heard of someone using the jx case and the speed piston and sleeve, but I don't know real world results. Is the speeds case that much different from the jx case? Maybe I should just simplify this and get a new speed piston and sleeve. It always ran good, I just feel like I could use some more bottom end for some of these short run up jumps. I don't really even know that the jx piston and sleeve would do that, but I am sure someone around here does.
Old 02-07-2009, 11:39 PM   #5
The JX internals will fit in a vspec case. The only difference is case volume and its very hard to tell in a vehicle. JX Internals are almost exactly the same as speed vspecs.
nitrofreak32 is offline   Reply With Quote
Old 02-08-2009, 06:51 AM   #6
mfrosty's Avatar
Trader Rating: 14 (89%+)
You could always just gown down a tooth on the cluthbell or tune your clutch for a little more punch for those short run jumps.
mfrosty is offline   Reply With Quote
Old 02-09-2009, 09:41 AM   #7
JayL's Avatar
I know the black coat is pretty, but isn't the jx-21 case better in that it doesn't have the cracking issues the speed and v-spec cases have?
JayL is offline   Reply With Quote
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
ALTOONA RACEWAY FORUM Ed237 Track Locator Forum 9108 06-28-2011 05:10 PM
Lots for sale!! Check this out!! NIB RC8T and OS28XZ inside... Plus More! DavidR R/C Items: For Sale/Trade 15 02-24-2009 07:14 AM
Engine Recommendation MFDFireCam Nitro On-Road 8 03-14-2004 05:59 PM
