Old 02-06-2009, 09:02 AM   #16
Originally Posted by Jaz240 View Post
I agree! I wasnt even paying attention to the fact that you are running 30%. Your button might not be shimmed for 30% (not sure about that though), that would explain all your problems right there.
does anyone know if the stock shim height is good at 30%?
Thanks for all the replies folks. I know the head has 1 copper gasket installed from factory. Also, I am about out of fuel so I have no problem buying 20 or 25 % fuel.
thanks
chris
schultztec is offline   Reply With Quote
Old 02-06-2009, 12:17 PM   #17
elkman's Avatar
Default Another copper gasket
I have an 8IGHT with a 427 and put a second copper gasket on the head and run odonnel 30% with an OS LC3 plug and 8 tanks of fuel so far the plug looks brand new, That was with several starts and stops (restarts)
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 02-06-2009, 12:39 PM   #18
More info,
I have completely tore down the engine this morning to check everything out and there was not much that was discovered. piston looks good no pitting or scoring, cylinder wall looks good as well. pinch/compression feel good.
I re-sealed the engine completely and the leak test passed. the only thing I found was the exhaust rubber gasket was a little chunked up so I replaced it with a new one.
PS - Since I have owned this engine, It seemed to me it would never run consistant, meaning it felt like there was an air leak somwhere. It would run good for a tank or two and then It would not want to restart or idle properly, This would occure all in the same day at the same track. There would be very little to no change in outside temp. (indoor track).
With all that said, I am somewhat new to this but the people that hae been helping me are not.(one gentleman is an ex losi sponcered driver and a current kyosho driver).. and everyone just seems to be scratching there head at this point..
thanks for all the info folks
chris
Old 02-06-2009, 12:42 PM   #19
Also, I have performed a leak down test with the fuel tank and fuel lines as well and it all loos good
chris
Old 02-06-2009, 03:19 PM   #20
Chill_Will's Avatar
Trader Rating: 32 (100%+)
chris
Is this a new motor? If not, how much fuel has been ran through it?
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 02-06-2009, 08:21 PM   #21
yes sir,
It came in a rtr losi8 i bought new. I have just under a gallon through it.
thx
chris
Old 02-10-2009, 08:15 PM   #22
JW RACING's Avatar
I to was having this problem...but i was only geting a tank of fuel per plug....
on 30% byron....now runing 20% with os a3 plug an jp3 pipe man that thing rips now...i'm runing a 8t....good luck maybe some more run time will help to.....
LOSI 8IGHT
LOSI 8IGHT-T 2.0
John W.
JW RACING is offline   Reply With Quote
Old 02-11-2009, 07:10 AM   #23
sidewaze's Avatar
It's your percentage as even Losi documentation recommends 20% for that motor. I run Sidewinder 20% and haen't had any issues
Team Novak tech@teamnovak.com | Pinnacle Freight Specialists www.pinnaclefreight.ca
Trick Parts Trick-Parts.com Stainless Steel screw kits lifetime warranty
Xray T3'11 Havoc Pro SC/17.5 Ballistic| Xray T2'008 Havoc Pro SC/21.5 Balistic CVTA
WGT CRC Gen-X 10LE Havoc Pro SC/17.5 Ballistic| CRC GenX Havoc Pro SC/17.5 Ballistic
Action Hobbies Kingsville | Lou's Speedway Dorchester www.lousspeedway.com
sidewaze is offline   Reply With Quote
Old 02-11-2009, 07:13 AM   #24
Chill_Will's Avatar
yes sir,
thx
chris
Like they said, run 20%. Thats what I run in mine and I get good power. I found that this motor runs good at about 230-240 degrees.
Old 02-11-2009, 08:39 AM   #25
scwrod's Avatar
plenty of good advice here. The MC plugs are great plugs and the price is good.
I had to stand up for a plug that has served me well
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 02-11-2009, 07:11 PM   #26
Thanks again everyone for all your help, I will def try all of the suggestions everyone has provided. If nothing else I am learning my way around these engine.
thanks
chris
