Old 05-30-2009, 04:11 PM   #61
GREGORY!'s Avatar
arm2storm i am sorry,i made a mistake.it does not has any restrictors.
but i am pretty sure that the previous carb can be used.the same as jammin.
GREGORY! is offline   Reply With Quote
Old 05-30-2009, 08:32 PM   #62
Trader Rating: 25 (100%+)
Thanks Gregory.
arm2storm is offline   Reply With Quote
Old 05-30-2009, 09:14 PM   #63
Hi All,
Found this on the net. Picco Evo 3 with carb restrictors, check it out.
Link: http://cgi.ebay.com.au/NIB-Picco-P7-...3A9%7C294%3A30
Jesussaves is online now   Reply With Quote
Old 05-30-2009, 10:23 PM   #64
aussies1129's Avatar
Trader Rating: 74 (100%+)
I have got a serious tune issue with my evo 2 possibly due to using odonnell 99 plugs so i am trying mcoy8?? does anyone have a factory setting for this engine so I can start again?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 05-31-2009, 07:01 AM   #65
vladconnery's Avatar
Trader Rating: 35 (100%+)
cheers
First get rid of that odonell plug. Use the props picco plugs. If not available in your area use RB6's they will work fine. However picco plugs ate different fm other plugs.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 05-31-2009, 05:33 PM   #66
Integra's Avatar
cheers
I suggest sealing the carb up and going to a turbo head button and ONLY use genuine picco/ofna plugs....they are imo the best for the $ NO QUESTIONS asked....what is the tune issue btw ?
Old 05-31-2009, 06:05 PM   #67
Madbrad's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Jesussaves View Post
Hi All,
Is this motor different than the one this thread was started about? I thought the Picco .21 EVO 3 had a blue head ?
Madbrad is offline   Reply With Quote
Old 05-31-2009, 06:45 PM   #68
GREGORY!'s Avatar
no.this version is called mw or something like that and if i am not wrong is from german.i don't know if has any different in timing.
Old 05-31-2009, 10:38 PM   #69
The early EVO 2 and EVO 3 had the carb you can change the carb insert. The late ones you cannot change. It would be nice if Ofna and Nitrohouse would update the website
pdmustgt is offline   Reply With Quote
Old 06-01-2009, 06:55 AM   #70
keep on flaming out and its running really rich but I think its a combination of crap fuel brand and wrong plug and not enough time before a race to give it a good tune up I tried the mccoy #8 and it runs better and has a far better idle. can someone give me a run down to why I would want to use the carb restrictors??? also i am running 25% nitro whats a good oil content with that??
cheers
H.E.I AUSTRALIA
Old 06-01-2009, 07:06 AM   #71
Integra's Avatar
cheers
you need to be more concerned about why the motor's doing what its doing besides what restrictor's do.......the picco carbs can leak in multiple place's and cause a nightmare of a time tuning them......the main body where the composite meets the alum needs to be sealed....if the base of the carb is not pressed in enough the base can leak and cause issues....the needle's can also leak through the threads causing issues....how old is this motor ?
Old 06-02-2009, 05:05 PM   #72
Default re
Ihave had 3 evo 2r piccos have found that odonnel plugs work well but if you ar eusing a higher oil content fuel could be a prob my piccos run well on trinity platinum and blue thunder hp8 lasted around 8 gallons then the bearings went out p/s still wont push thru the top always ran around 220 230 degrees with a 2013 pipe smooth round header piccos do not like to be fat on the low end found out the hard way many flameouts the best way ihave found to tune the picco is run almost a tank of fuel then refill ge top end somewhat close then tune the low so it drops to a regular idle without staying high at all
toofless is offline   Reply With Quote
Hyper 9 Kits in Stock! bola Nitro Off-Road 2373 01-02-2013 03:43 PM
