The BUKU BOMB! The 007 is almost out
Location: It doesn't matter as long as it has R/C Racing!
I'm all worked up and ready to run with a new GRP 21 mounted and the new BUKU 007 nearly final prototype. I'm about to set off for the 2009 Texas Twister.
If I don't place well it's not the truck I've only been behind the wheel of something Nitro for about a gallon since last July roughly...so I'm off my edge you could say.
This pipe is the bomb!!! It is now 100% ROAR and RC Pro legal in everyway and form.
www.bukupower.com
Just in the same fashion as tuning your needles on your carb to lean and rich
your engines with this pipe if you need more highend or need more lowend power you tune the pipe to give it to you without taking ANYTHING a part.
You don't even have to turn your car off do it!!!
No more compromise between pipes that are close to what
your motor needs. No more need to have more than just 1 single pipe
period. Switch engine brands...fine! You don't need a new pipe! Go
from a 21 to a 28...fine! You don't need another pipe! You need more
top end on the engine you have now because your track is long...you
don't need another pipe. Your local track is short and sprinty with lots
and turns and short runs into jumps that you have to have torque
to hit...fine! You don't need another pipe!
No more playing the game with the "long header" on this pipe...and a the "short header" on that pipe to get just close to the power band you need!!!
Just tune your Buku 007 to give you the exact power band setting you
need for where you are...what you are running no matter what your
conditions are. This is the only pipe you need in your box and on
your cars. The reasons why will become more clear as we get these
into production very very soon. Expect to see a Pro-Level Podium
soon running one of these pipes on there trucks and buggies...it's
gonna happen and your gonna want one of these things so bad it will hurt!
This thing does what you want it to do...just with a simple pit lane tune.
I should have a few prototypes on hand this year at the race...
they are nothing at all like what we had last year...nothing!
www.bukupower.com
do they sell a polished version?
wow, I can barely read all that mumbo jumbo. I can't keep up with the mis-spellings and punctuation issues. You'd probably make more of a positive impression, by proof reading your post before hand
The pipe looks interesting, can't say I'm in a hurry to get one. Not to mention I doubt it would fit in a buggy.
Buku Pipe
Buku Price
Buku Hype
Buku Whack!
Buku Price
Buku Hype
Buku Whack!
Here's a vid where the buku pipe doesn't do all that well:
http://www.youtube.com/watch?v=3UdFs1gSix4
as far as im concerned...Hara and his Speed won the race....not the D8.
This is supposed to be about that Buku pipe not who won the worlds or got lucky or what have you.
Keep it sort of on topic.
My friend tried 2 of these pipes before the 007 of course and they did run well at first but fell apart soon after. Not sure what the problem was it was awhile ago but it was either a problem with the internals of the pipe or the joint where the pipe goes together. Not sure. Did not last that long for the money. Of course that is just one experience with the pipe so maybe just 2 bad ones. These might be better.
