Old 02-06-2009, 08:41 AM   #31
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Originally Posted by pballer2777 View Post
i really dont have a process. i'm just trying to find the best way. the few times i tried it was just a trainwreck. so i'm trying to get some advice.
1) It's MOST IMPORTANT to use a High Quality CA Glue Made in the USA... I say this, cause glue that comes in from overseas has sat in a EXTREMELY HOT SEA Containers during shipping rendering the glue useless.( very important)
2) Tony N. is correct about NOT using Alcohol. (very bad) Alcohol, and motor-spray, causes the tire to leach oils from within the rubber. (not good for CA)
I use nothing, just a clean rag, and wipe clean.
3) (Most common mistake) When gluing most ppl try hard to get the glue deep in the bead. This is NOT necessary, and can get your tire glued to the rim were you don't want it, and or your fingers..lol I put the tires on the rims so they're in the bead perfect, then put on your mounting bands, then lightly pull back on the tire just enough to expose the outer side of the bead (so if you were to let go of the tire, the bead would pop right back into place with no fuss.) apply glue in that lil exposed area.. the glue works it's way deep in the bead..Trust Me!
All the cleaning, and sanding is good, and can help, but it's really time consuming, and not necessary if you use HIGH QUALITY MEDIUM CA MADE IN THE USA.. HOPE THIS HELPS GOOD LUCK!
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 02-06-2009, 11:41 AM   #32
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Originally Posted by Jmnay_83 View Post
So Tony you just glue around the bead and that is it. You dont put any between the bead and rim?
When its time to put the CA in there I have the tire on the rim... but no bands.... Then I'll squirt some CA in between the rim and tire.... THEN put the band on last.
Wassup Joe.... You still got my number? My phone took a dumb this week... should have a freshy by sunday, give me a ring if you got a min.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 02-06-2009, 11:48 AM   #33
jpalessi's Avatar
Whats up Tony! I'll give you a call Sunday, in between rounds lol...
Sucks to hear you won't be at Motorama!
Joe Alessi
www.Lucky7RC.com
Old 02-06-2009, 11:49 AM   #34
ya... some things didnt work out.... I'm sure you've caught some it it lol
Old 02-06-2009, 04:22 PM   #35
SPARTAN300gt's Avatar
dude if this has good results maybe ill try it, ill admit all the sanding and cleaning is a huge pain in the @$$, its just something that gets beaten into peoples heads after awhile and it makes sense to me to prep everything good, thanks fo the info on the alcohol, ive never had a problem with tire coming off or not being true but this sounds much faster
SPARTAN300gt is offline   Reply With Quote
AKA tires ALG Nitro Off-Road 1793 11-04-2016 06:37 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 06:38 PM
Tires will not stay on wheels maximumhp Nitro On-Road 12 04-23-2009 04:52 PM
The art of tire gluing. CE28N Electric Off-Road 15 09-12-2008 05:53 AM
AKA Tires......Release Date? Newell33 Nitro Off-Road 69 09-11-2008 12:21 AM
COBRA RACING LOOKING FOR A,B,C MAIN DRIVERS AND LOCAL CLUB DRIVERS COBRARACING Nitro Off-Road 259 04-18-2008 06:25 AM
Tire Gluing acutts Electric On-Road 15 06-01-2005 04:04 PM
