Old 02-05-2009, 01:04 PM   #16
mt bands
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
Old 02-05-2009, 02:12 PM   #17
DriftProjectR's Avatar
Trader Rating: 38 (100%+)
http://www.youtube.com/watch?v=6ux4JP_BiS0
try this video, i been doing this way for years now and it works great!
Hot Bodies IFMAR Worlds
OS Engines
Ace Servo
BCE Design
Bodies By Scott
Lungsford Titantium
M2C Racing
DriftProjectR is offline   Reply With Quote
Old 02-05-2009, 03:23 PM   #18
Integra's Avatar
X2 for the Panther Bands....i find the tape method and the 500 small elastic bands is a waste of time.
Old 02-05-2009, 05:36 PM   #19
SPARTAN300gt's Avatar
practice does help, but its not that bad, make sure your using a good glue with a wick in the end of it, also make sure your in the right state of mind and relaxed( not as soon as you get home from work ), ive glued countless sets of tires and wheels and they come out pretty good, nice and true and straight not that i havent f@#% up a few sets
1) scuff up bead on rim and bead of tire (dremel works perfect)
2)wash, wash, wash, i clean my rims with hot soapy water and the tire beads with rubbing alcohol and an old whit t-shirt
3) also check the tire beads to see if there is any flashing that should be trimmed off and be sure to put the holes in your tires before mounting
4) mout the tires and secure them with heavy rubber bands, its easiest if you do 4 tires at a time but only one side of each tire at a time
5)pull the beads back just far enough to get the wick in there, no too much glue itll squeeze out if you do, also it helps if you can stand the tire up and let the glue run down the bead, do this in 8 differrent spots, let them sit 15 min and try pulling the tire away from the rim and keep touching up the spots that do
6)finally once the tire is fully glued i run a bead around the outside to seal things up, stand the tire on end and place a few drops on the bead and let it flow around the rim, you will have to keep adding glue and spinning the tire
hope this helps, it is a lot of work but the results pay off
SPARTAN300gt is offline   Reply With Quote
Old 02-05-2009, 08:37 PM   #20
Integra's Avatar
1 thing i dont do anymore is a Final Thin bead around the whole tire...i found the glue to always let go and require constant retouching.
Old 02-05-2009, 08:48 PM   #21
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Everyones got theyre way.... I used to do like in the video, but sometimes they would come undone.
I always dremel only the tire, I wipe both the tire and wheel with Acetone. Not sure why but when I quit using alcohol I had way better results.
I'll put holes in the wheels or tires, depending on if teyre for indoor our outdoor. I'll get them mounted up, straight and make sure the beads fit nice. Then I'll run a bead of medium CA all the way around the bead, then put the panther band on and let it dry.
Since I've been doing it this way, theyre perfectly round, no wobble and never come unglued.
Acetone I think is way better than alcohol for some reason.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 02-05-2009, 10:09 PM   #22
Trader Rating: 19 (100%+)
Default Tires
So Tony you just glue around the bead and that is it. You dont put any between the bead and rim?
Jmnay_83 is offline   Reply With Quote
Old 02-06-2009, 03:56 AM   #23
redza's Avatar
does normal selley's super glue work for gluing tires?
Tebo is the man.
redza is offline   Reply With Quote
Old 02-06-2009, 05:36 AM   #24
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I really like the OFNA tire glue machine. Just did 16 tires yesterday. Fast, easy, no mess, perfect.
cpaurl
rallyebmx is offline   Reply With Quote
Old 02-06-2009, 05:54 AM   #25
HulkNT1's Avatar
What kind of tires can be glue there?? Truggy and buggy??
HulkNT1 is offline   Reply With Quote
Old 02-06-2009, 07:43 AM   #26
Poppin Fresh's Avatar
That OFNA tire gluer is a joke and a waste of money. It misses it's beads. Just practice gluing tires. You have the steps right.
"Nothin says luvin like fresh baked muffins, woohoo!"
Cruizin With R/C, RCBZ, Xray, Hudy, Novarossi USA, Futaba, Avid RC
Poppin Fresh is offline   Reply With Quote
Old 02-06-2009, 08:01 AM   #27
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Originally Posted by pballer2777 View Post
i usually do buy premounts but as of yet aka doesn't have yellow premount truggy tires.
dude aka truggy tires have to be the easiest tires out there to glue..
Your process sounds correct, except using the alcohol to clean.. so what is the prob exactly? tires come unglued? What glue are you using? What rims are you using?
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 02-06-2009, 08:16 AM   #28
pballer2777's Avatar
Trader Rating: 27 (100%+)
i really dont have a process. i'm just trying to find the best way. the few times i tried it was just a trainwreck. so i'm trying to get some advice.
pballer2777 is offline   Reply With Quote
Old 02-06-2009, 08:17 AM   #29
oh the tires i will b attemping will be aka. everything aka rite down to the glue.
Old 02-06-2009, 08:39 AM   #30
rallyebmx's Avatar
Buggy and touring car. I have glued all my tires with this for 1.5 years-perfect.
cpaurl
AKA tires ALG Nitro Off-Road 1793 11-04-2016 06:37 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 06:38 PM
Tires will not stay on wheels maximumhp Nitro On-Road 12 04-23-2009 04:52 PM
The art of tire gluing. CE28N Electric Off-Road 15 09-12-2008 05:53 AM
AKA Tires......Release Date? Newell33 Nitro Off-Road 69 09-11-2008 12:21 AM
COBRA RACING LOOKING FOR A,B,C MAIN DRIVERS AND LOCAL CLUB DRIVERS COBRARACING Nitro Off-Road 259 04-18-2008 06:25 AM
Tire Gluing acutts Electric On-Road 15 06-01-2005 04:04 PM
