Old 02-05-2009, 03:55 AM   #1
mini696's Avatar
Default Stalling after pitting.
OK... Common question time.
My car has now begun to develope a habit of stalling if I gun the throttle hard after pitting. I have to do a lap being ginger on the throttle otherwise the car gets a free lift back to the pits.
What could be causing this?
D8, GO 5Port
Ve8, RX8 1900, Promatch 5100 4S
SC10, Hobbywing EzRun
mini696 is offline   Reply With Quote
Old 02-05-2009, 04:23 AM   #2
Unless you have air leaks your fuel line from the tank to the motor is to short.
The Working Man is offline   Reply With Quote
Old 02-05-2009, 04:30 AM   #3
mini696's Avatar
No air leaks. I test for that every outing.
How does a longer fuel line help.
My line is quite long already, so maybe I have missed an air leak...
Could be engine tune though.
D8, GO 5Port
Old 02-05-2009, 04:46 AM   #4
bjr48's Avatar
Just two guesses -
If it's tuning - bottom end is a little off, probably rich.
You are over filling the tank?
Hope you find it soon. I've expereinced the opposite - runaway throttle when pitting and it took me a couple of weeks to find the air leak. You obviously have a different problem but just as frustrating. good luck
bjr48 is offline   Reply With Quote
Old 02-05-2009, 08:03 AM   #5
kevinmajor's Avatar
A full tank of fuel gives the engine a richer feel than a tank that is half full. As the tank empties, it will lean out. So, it sounds like your bottom end is on the rich side. Try the pinch test by pinching the fuel tube about 1 inch from the inlet to the carb. The engine should run for about 3-5 seconds. If it runs longer than that, you are too rich and should lean the bottom at about 1/8th turn each time. Keep doing that test untill you get within the 3-5 second window.
kevinmajor is offline   Reply With Quote
Old 02-05-2009, 08:10 AM   #6
Trader Rating: 66 (99%+)
+1 to above post^^
sounds like the low end is loading up.
pwnzor is offline   Reply With Quote
Old 02-05-2009, 09:41 AM   #7
Trader Rating: 27 (100%+)
Try pitting a lap earlier and see if it still does it. Could be getting to lean when the tank nears empty, or just coming in to close to empty all together.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 02-05-2009, 10:28 AM   #8
CHogle's Avatar
Send a message via MSN to CHogle
Are you running the d8 or losi, look at number 3 if you are
you could be having one or maltiple of the following issues
1.rich low end needle
2.air leak
3.the tank in the d8 and the losi is a little differant than than normal. the fuel leaves the tank at a lower exit point. when your at the end of a tank and you refill the car quickly the tank self primes. so you go from running with air bubbles in most of your line to solid guel and this loads up your engine.
i found that if you mount a fuel filter on your line it will increse runtime a little for when your cutting it close on fuel. also i feel that fuel filters allow a more consistent fuel flow to your engine this should also lessen the amount that your tank self primes.
the second thing that ive found to work well, is to mount you fuel line so it above the fuel exit point of the fuel tank. this will eleminate the tanks self priming, and make you engine more consistent.
i would look at the tank last. make sure that you do not have a air leak or something stupid thats messing with the engine gitting to little or to much fuel.
bast of luck, hopefully you get it figured out
C.HOGLE
Serpent America, Novarossi, O'Donnnell fuel, PT Racing Oils, SMC, H-bomb Designs, Stick it 1 racing, Motor Savor Filters, Fastraxx Hobbies
CHogle is offline   Reply With Quote
Old 02-05-2009, 10:50 AM   #9
Be sure to clear your engine out after it's fueled. Have your pit guy hold it up for half a second or so and give it a couple good revs before he sets it down.
cjtamu is offline   Reply With Quote
Old 02-05-2009, 11:06 AM   #10
losi_racer's Avatar
Trader Rating: 25 (100%+)
thats just wasted time, unless you have a system going which would never be 100% right your pit guy would get hurt. if your buggy is doing somethin it not supposed to do then you need to fix the problem. which most people have said that its to rich and i must agree
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 02-05-2009, 03:03 PM   #11
Had the same problem w/ my sons buggy. After replacing fuel lines it's o.k. What i think was happening was the fuel line was a little soft or possible pin hole & it would not presurize the tank quik enough. When i got the buggy there was no fuel in the line. It also seemed to take too long to fill the line when first starting after running out of fuel. Hope that helps. Let us know what fixes it.
romax is offline   Reply With Quote
WERKS RACING (Malaysia) - updates, comments, enquiries, feedbacks and ask our drivers spencer Malaysian R/C Racers 355 10-26-2008 09:16 PM
Pitting Trick to blow the competition V1-RRR-WC Nitro On-Road 21 07-17-2007 06:56 PM
