Old 02-04-2009, 08:39 PM   #1
heeltoedrver's Avatar
Default 5port vs 7port
what are the pros and cons for 5port and 7port race applications?
Team Terribles
heeltoedrver is offline   Reply With Quote
Old 02-04-2009, 08:58 PM   #2
xlgraphicspro's Avatar
Well, it's hard to say because not every motor is the same. like the 5 port ninja JX isn't the same as an rb S5.
Hell, my O.S. Speed is just a 3 port motor, and I bet you it can haul a$$ around alot of 5, and 7 port engines. Generally the fewer the ports the better the fuel mileage, but that's not always true either.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 02-04-2009, 09:03 PM   #3
jpz_67's Avatar
Trader Rating: 56 (100%+)
Usually a 5 port engine will always have more bottom end grunt and get into power band faster than a 7port motor. With this being said a 7 port does not always have the torque of a 5 port but will usually move the power band over to the right, meaning it will perform better in the upper rpm range, more top end. There are times I prefer a 7 port such as big fast tracks, slick or loose conditions, etc. On a smaller tighter track the 5 port would be the way to go, more speed and power from turn to turn. For most of the tracks here in the States a 5 port would be optimum. Good luck.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 02-04-2009, 09:11 PM   #4
Jaz240's Avatar
Trader Rating: 52 (100%+)
Generally like the other said, the more ports amotor has, the shorter the runtimes, and the better top end it has. less ports=more torque..... More ports=less torque, more top, you can make adjustments with the right pipes
nothing to see here................................
Jaz240 is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 03:46 PM
