Old 02-03-2009, 04:59 PM   #1
ngl
ngl's Avatar
Default Rc8 shock limiters
does anybody know how you do the internal limiting on the rc8 standard shocks?
and what does this do for the car?
ngl is offline   Reply With Quote
Old 02-03-2009, 05:43 PM   #2
I use 2mm in front and 4mm in rear. I use the small black plastic spacer that goes in between the o-rings. You can get them out of the shock rebuild kits. they measure 2mm so they work perect and they fit the shock shafts perfect. Remove the shock shaft, put the limiter over the shaft then install and finish rebuilding the shock.
SPEEDSKI is offline   Reply With Quote
Old 02-03-2009, 05:53 PM   #3
ngl
ngl's Avatar
thats in the shock, below the piston right?
Old 02-03-2009, 06:05 PM   #4
Trader Rating: 27 (100%+)
Correct.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 02-03-2009, 06:09 PM   #5
ngl
ngl's Avatar
and so this is going give the shocks less up travel, what will that do for the car?
Old 02-03-2009, 06:23 PM   #6
Limiters go inside the shock body, and underneath the piston. So they stop the piston from going all the way down to the bottom of the piston. So they reduce downtravel, the uptravel is still the same.
This will reduce body roll in corners and make for a quicker reacting, feeling car. It also helps keep weight over the front when accelerating, and over the rear when braking. It's all minimal, and you just have to try it and see if you feel a difference.
Old 02-04-2009, 04:31 AM   #7
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i bought spacers at ACE to use for my limiters.. i found ones that were the exact same size as the ae ones. Just thought i would post that in case somone needed them in a hurry
jamminnay is offline   Reply With Quote
Old 02-04-2009, 08:01 AM   #8
What isle were they in? I'll have to go look around there later.
Old 02-04-2009, 08:14 AM   #9
PTP Racing's Avatar
AE now sells them separately
89067 1/8th shock limiters
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 02-04-2009, 11:17 AM   #10
jamminnay's Avatar
i found them with all of t he nuts, bolts, and etc... i took my calipers in there with me so i could find ones that fit perfectly.
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
2 rc8t 1 rc8 and strr and box of parts. jeff alessi 801 R/C Items: For Sale/Trade 35 05-05-2009 01:01 PM
RC8 setup Info?? TXRC8racer Nitro Off-Road 13 04-01-2009 11:09 AM
AE 16mm BIG BORES shock oil? TXRC8racer Nitro Off-Road 17 02-24-2009 09:13 AM
