Old 02-03-2009, 05:11 AM   #1
Gen
Gen's Avatar
Default droop,how to adjust ??
how do you adjust droop simply ,,everyone i speak to seems to have different idea on how to adjust please explain ??
Kyosho MP9 tki3
Kyosho Strr Evo
Os engines
Vp race fuel
Futaba 4pks
Gen is offline   Reply With Quote
Old 02-03-2009, 05:22 AM   #2
Matt Howard's Avatar
By adjusting the "droop" screws in the arms. It controls how far down the suspension can travel, or "droop". On some electric cars you have to unscrew the shock to get more droop since those cars don't have droop screws.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-03-2009, 05:43 AM   #3
bjr48's Avatar
In the past I have generally set the droop to not allow the shocks to extend past their natural stopping points. What is droop really meant to be set for if you ignore the shock travel?? I've got the Hudy book so I'm sure I'll figure it out eventually but what is the main point of droop?
bjr48 is offline   Reply With Quote
Old 02-03-2009, 05:46 AM   #4
BAUSTIN's Avatar
i measure my shock length.........
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 02-03-2009, 08:02 AM   #5
Trader Rating: 19 (100%+)
Default Droop
I measure from the middle of the top shock bolt to the middle of the bottom shock bolt with a set of digital calipers. The car must be set up off of the ground while you do this. I usually set it up on a set of wheels or something while I measure it. Then after I set the droop I set my ride hieght with the car sitting on a level surface using an associated ride hieght gauge.
Jmnay_83 is offline   Reply With Quote
Old 02-03-2009, 09:22 AM   #6
slow coach's Avatar
simply you put a hex driver in the droop screw and turn it, you might be after how do you measure droop or what you might be after is what effect changing droop has on the handling ?? this is a different thing altogether
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 02-03-2009, 09:48 AM   #7
bjr48's Avatar
http://www.rcxray.com/documents/xb80...Setup_Book.pdf
I think that's what we're asking here - is what does it do for you.
After reading the hudy book, I am going to set mine exactly at the limit of my shocks. Then if my buggy could benefit from less travel I'll adjust it more.
Hudy calls this downstops not droop and there is an explanation in there with a chart after telling you how it effects weight transfer and front and rear traction, etc. It really is another adjustment that can alter 2 or 3 different things just like everything else. Unless you can get someone at your track to tell you how to set droop for your track I would start with as much as the shocks allow and get all of your other setup as good as possible then play some with droop and ride height later on Don't forget that droop(downstop) and ride height are two separate things here! I'm just getting into the fine art of setup here myself but that's what makes sense to me
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Team Associated Factory Team RC10R5 tyreguy Electric On-Road 871 10-16-2013 09:35 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
jumping tips????? tweeter79 Electric Off-Road 22 08-01-2009 10:00 PM
Tamiya Mini Cooper Club SuperEk4 Singapore R/C Racers 1123 06-20-2009 08:49 AM
Can somebody explain droop in detail? holycow Electric On-Road 26 10-08-2003 10:52 AM
