Old 02-02-2009, 07:08 AM   #1
Default Helical vs. straight cut diff gears???.....
I downloaded the manuals for RC8, MBX6, 8ight 2.0, D8, XRAY 808 and MP9. I noticed that only RC8 and D8 use helical cut diff gears n pinions, MBX6 has it as an option, the rest come with straight cut diff gears. In theory, helical cut gears should be better and can handle higher stresses (assume same material) than their straight cut counter part. Has anyone experienced the differences in performance on the track for these two types of gears?
Thanks!
ganymede is offline   Reply With Quote
Old 02-02-2009, 07:54 AM   #2
Helical gears operate smoother than straight cut gears. Should result with faster acceleration too. Felt that way when I switched over from a Jammin x1-crt to the x2-crt
Genius is offline   Reply With Quote
Old 02-02-2009, 07:59 AM   #3
Tony Newland's Avatar
Trader Rating: 50 (100%+)
helical are smoother and stronger, less likely to push the ring gear away from the pinion under acceleration. They are also a tad more work to shim to find the "sweet" spot.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 02-02-2009, 08:09 AM   #4
I have never had issues with a straight cut in buggy. But like Tony said, the Helical takes a bit more shimming to get correct, after a few checks for play, you are golden. I found this out the hard way. lol
Team Horizon - Viper RC Solutions - Dynamite - Blue Thunder - Spektrum - JConcepts - Full Nelson Designs - RW Mods
KendallWelch is offline   Reply With Quote
Old 02-02-2009, 08:14 AM   #5
Straight cut gears produce less friction.
topcat-lll is offline   Reply With Quote
Helical vs. straight cut diff gears???..... ganymede Nitro Off-Road 48 05-29-2011 09:18 AM
