Old 05-26-2011, 06:13 PM   #16
The spiral cut bevel gears are smoother and quieter than the straight cut bevel gears. I don't believe there is an advantage as far as strength.
statengineer is offline   Reply With Quote
Old 05-26-2011, 06:14 PM   #17
j_blaze14's Avatar
Trader Rating: 34 (100%+)
true, when the spiral cut are not meshed right they slip and round off. the straight cut seem to just snap off teeth if they go. as long as they are shimmed right and the bearings are good either should last a long while.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 05-26-2011, 06:21 PM   #18
pitpop's Avatar
The MP9 has straight cut gears and arguably the best drive train that has ever been produced. Just spin somebodies MP9 even with the wheels off, it's pretty amazing. The ST-RR uses spiral cut, and you definitely have to mesh it just right and limit the front brake.
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 05-26-2011, 06:59 PM   #19
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
I run Grease on my ST-RR Spiral gears. Do you treat Straight cut gear the same?
Jeff Werner is offline   Reply With Quote
Old 05-26-2011, 07:02 PM   #20
madac's Avatar
My eight-t with the straight cut gears I would go through a pinion shaft every half a gallon on the front and rear and had to make sure the mesh was good and shimmed properly. On my D8 and D8T the spiral cut gears I put them in and the only time I took them out was when I was changing the diff fluid out, never found any filings come off of them and haven't changed them since I got the new buggy and truggy. I imagine maybe I may have done something wrong with the straight cut gears but even the other guys at the track helped me with shimming and setting it up but that didn't make any difference in the wear. I like the gear mesh of the spiral cut gears maybe I just have bad luck with the straight cut gears.
Team Associated B5
Spektrum DX3S
madac is offline   Reply With Quote
Old 05-26-2011, 07:59 PM   #21
Talking about full size car, here's a picture of a Porsche Cayenne's diff, note the helical/spiral cut gears...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 05-26-2011, 08:07 PM   #22
johnny t's Avatar
You do a helical style cut of a gear to reduce noise pretty much. these days you have to be conscious of passenger comfort in our little cars.
I wish those manufacturers would drop the sexy looks and increased drag of a helical cut and go straight cut, they are not doing us any favors me thinks. Race cars are straight cut.
johnny t is offline   Reply With Quote
Old 05-26-2011, 08:12 PM   #23
tc5 man's Avatar
i like helical cut diff gear better than the straight cut on my rc8t i just used 1 shim on each side" like the manuel says and its good no failures and man is it smooth and it spins pretty free !
now the helical cut diff gear is harder to clean though if needed.
tc5 man is online now   Reply With Quote
Old 05-26-2011, 08:19 PM   #24
omarwashington's Avatar
If it works for pencils then its good enough my my diffs
RCCARS!
omarwashington is offline   Reply With Quote
Old 05-26-2011, 08:52 PM   #25
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
+1.
infanterene is offline   Reply With Quote
Old 05-27-2011, 12:05 AM   #26
madac's Avatar
I don't understand this but real race cars use straight cuts to the diff and the ring gear? I have looked through nascar, indy and formula one teams pages and looking to see this for myself and they had cut away sections of where the shaft and the pinion gear go to the ring gear and they were all helical or spiral gears but got sick of looking after looking at over 40 pages and couldn't find one with a straight cut pinion to diff ring gear. If a Porche has runs spiral or helical gears it can't be that inefficient and the Germans don't do it if it's a waste of time but more likely it's more efficient and probably a better mesh. I don't know. OOOOOOOOOOOOOOHHHHH WELL!!!!
Team Associated B5
Spektrum DX3S
Old 05-27-2011, 04:04 AM   #27
duck7604's Avatar
The reason behind helical cut gears is more surface area per gear tooth than straight cut gears and they are quieter than straight cut. You guys keep talking like it's something from another planet
Losi 8ight 2.0EU
Novarossi plus 4 btta
Airtronics MX-3X
Savox Servos
duck7604 is offline   Reply With Quote
Old 05-27-2011, 07:05 AM   #28
Jesse Robbers's Avatar
Send a message via AIM to Jesse Robbers
That Porsche gear looks like it might be a hypoid gear (the two gear axis don't intersect). Given the same width, the helical gears will be stronger, the running tooth width is wider giving it more strength. Helical gear teeth 'roll' or ease into mesh and out of mesh, this makes them quieter and smoother. Straight cut teeth go into and out of mesh all at once. This creates a bit more noise and vibration because the contact of the tooth width happens all at once. Efficiency, I don't know. I've seen Kyosho, Losi, and Serpent cars free spin very well and they have straight gears. I've seen my HB car spin very good with helical gears, but not as good as the Serpent I saw. Efficiency under load when the car is on the track could be a different ballgame but I think the gear cut style for r/c cars for the end user realistically only comes down to durability (how often you replace gears or gearboxes to keep the gears from skipping).
Sponsored by: O.S. Speed, KO Propo, Sidewinder, Tekin, Thunder Power, Lunsford, Skipgear.com, Fioroni, Avid R/C, GMK Supply, Competition Heat, Dialed Inc., LiveRC.com, DE Racing, CIG2O, ANDROID Nitro Runtime Calculator App
Jesse Robbers is offline   Reply With Quote
Old 05-27-2011, 10:36 AM   #29
johnny t's Avatar
We keep talking whether its a technology even beneficial to an RC car. I would say no, helical gears only slow our cars down. MP9s and 8ights proved that to me.
Old 05-27-2011, 11:20 AM   #30
slow coach's Avatar
tbf its not as easy as saying the losi or mp9 is faster than a helical diffed car, there are to many variables to even consider, bearings, mesh, options fitted, drive ratio etc will all make a substatial difference to how a car free wheels and accelerates.
is there a difference who knows, I went from the MBX5R to the 6 and didnt notice any real difference tbh, they both are very reliable when shimmed correctly, however i must say i never ever shimmed my MBX5 Prospec for about the first 3 years just let them rattle around in the diff till someone told me i should, did i ever break a diff gear no never.
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
