Old 02-01-2009, 01:25 PM   #16
my 8t was the rtr and the throttle servo died, i replaced it and never had a problem again, and replaced me steering servo when i thought it was going bad but the servo was fine, servo saver had skrewed down. is that usually what the problem is?
ajhaun is offline   Reply With Quote
Old 02-01-2009, 01:29 PM   #17
Jaz240's Avatar
Trader Rating: 52 (100%+)
Servo saver EPA (end point adjustment) and Tray cushioning are the 3 main reasons poeple blow servos in all vehicles..The Losi 1.0 just needs more attention than the others, but once done correctly you wont have any problems
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 02-01-2009, 01:32 PM   #18
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1 but also add linkage setup to that list. if you do this stuff right you will have no problems. 2 years on both losi 1.0 buggy and truggy with ZER0 servo failures.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 02-01-2009, 01:32 PM   #19
SPARTAN300gt's Avatar
+1, use the right servo for the application or theyre all servo eaters
SPARTAN300gt is offline   Reply With Quote
Old 02-01-2009, 01:32 PM   #20
im really leaning on the losi, i have the epa set right, but as for padding and stuff.. all advice apprieciated
Old 02-01-2009, 01:37 PM   #21
Well when you get the buggy it will have addendums in the manual. if you follow these to the T you will be golden. Very reliable, durable and fast buggy.
-Koby Kubrin-
Old 02-01-2009, 01:37 PM   #22
jrwoodchuck's Avatar
the most rear screw that hold the radio tray in (under the battery compartment) needs to be replaced with a 1mm longer screw. i used associated shock o-rings, but put two between the tray and the chassis for that screw. make sure you leave it loose enough that the tray will flex and not tight enough that the screw will protrude into the battery.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 02-01-2009, 01:37 PM   #23
just make sure you use the rubber grommets that come with your servo and make sure the servo case doesnt contact the radio tray all the way around it
Old 02-01-2009, 01:40 PM   #24
these Items should be included with the newer kits aswell as addendums as to how to do it all.
-Koby Kubrin-
Old 02-01-2009, 01:41 PM   #25
i didn't think of that, youre right.
Doug
TLR 22/M-11
Old 02-01-2009, 01:43 PM   #26
Hey it always helps to have advice anyway
-Koby Kubrin-
Old 02-01-2009, 02:31 PM   #27
thanks for all the advice, i ordered the stuff today, hoping it will be here before next friday night
Old 02-01-2009, 02:36 PM   #28
what ya get??
Doug
TLR 22/M-11
Old 02-03-2009, 11:58 AM   #29
losi 1.0
Old 02-03-2009, 12:12 PM   #30
losi 1.0
good choice!!
-Koby Kubrin-
