Old 02-01-2009, 08:46 AM   #1
CaptCrunch's Avatar
Trader Rating: 17 (100%+)
Default Glow Plugs, Glow Plugs, Glow Plugs....Help!!!
Hey Folks,
I've been collecting a hodgepodge of new or almost new engines over the winter months waiting for it to warm up here. I'm just getting back into the sport, and have about zero real-life experience with nitro. So... I've been buying inexpensive engines to re-learn to drive, and learn the twisty ways of nitro before dumping cash on good engines that I'd destroy. Between my Son-in-law and myself we have 2 Jammin CRT's and 3 Jammin CR's with a variety of engines:
Buggiy Engines
2 Hyper 21's
1 OFNA .21 4 Port
1 Rebuilt GS B01
Truggy Engines
1 Peak Racing Dragon .28
1 RB TM928
1 OFNA Force 26
Anyway, so I have this mishmash of engines, and I'm wondering if there are glow plugs that will work well with all of them, or am I going to have to use different ones with the different engines? Are there some basic rules of thumb in selecting the plugs? There seem to be ALOT out there and I can't make any sense of it. I understand that the percent of nitro in the fuel has a bearing on plug choice as does the ambient temperature that you run in, and I know that TOO hot of a plug can cause the engine to fire early. But I'm still a bit lost as where to start.
Thanks,
Kris
Never met an RC I couldn't crunch! If it never breaks, you're not playing hard enough.
Current Toys: 1990 RC10 Gold Pan buggy, 1991 RC10 Team Buggy, AE TC3, Diggity Designs XLR8, Tamiya TRF 415, Losi Mini Late Model, Losi Mini Slider, AE RC18MT, 2 Jammin X1X CR's, 2 Jammin X1 CRT Pro's, HPI Savage XL, Revo Platinum, Jammin X2 CR Electric Conversion, 4X2 Slash, 4X4 Slash, Losi Comp Crawler, Arrow Shark 47" Boat, Blade 400 Heli, Blade CX3
CaptCrunch is offline   Reply With Quote
Old 02-01-2009, 08:52 AM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
The Hyper .21's like Mcoy 8 (Medium) and Mcoy 59 (hot) The hotter plug will give you slightly better performance, but you need an crisper tune. The medium plug will idle better and make tuning easier, but steal some performance. Start with the MC8 and take it from there
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 02-01-2009, 09:13 AM   #3
scwrod's Avatar
+1 on the mc8 and mc59
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 02-01-2009, 12:59 PM   #4
CaptCrunch's Avatar
What about the other engines I listed? Will those plugs work well or will I have to have a different plug for each engine? I'm probably not as concerned for max performence as I am for reliable functionality right now. When I get to the point where I can make it around the track several times with out exposing the bottom of the chassis to the sunlight I'll standardize on a single engine for each class of car.
Old 02-01-2009, 01:11 PM   #5
Jaz240's Avatar
The Mcoys should be good for the other Ofna engines as well, not sure about the other engines listed..The RB might take a turbo plug...you really should use the factory suggested plug for each engine...there is no such thing as a universal Glow plug..some pugs are long some are short, then there is 5 different temperatures, turbo, and standard, long filiment short filiment..I highly doubt you can find one plug to work with all these engines, but the Mcoys I suggested will work with 3 of them!
Old 02-01-2009, 01:22 PM   #6
CaptCrunch's Avatar
LOL Well, that gets me HALF way there! I'll have to check with RB, Peak and GS. Thanks!
Old 02-01-2009, 01:45 PM   #7
Jaz240's Avatar
Welcome, good luck, have fun
Old 02-01-2009, 02:41 PM   #8
chunk t's Avatar
Kris,
Here are a few rules of thumb.
1. higher nitro % ...use a cooler plug
2. higher the compresion ratio ...use cooler plug
3. smaller the engine(<.18) ...use a warmer plug
4. richer fuel mixture ...use a warmer plug
5. higher RPM ...use a cooler plug
6. need better idle ...use a warmer plug
All of the engines you listed are .21 or larger so I'd recommend starting with medium/warm (MC-55, O'Donnell #1) and if those work well switch to a medium (O'Donnell #2), you could also go to the MC-8 (medium cool). I think the medium plug will give you a bit more life.
Some engines have "turbo" heads, the opening for the plug is smaller where it meets the combustion chamber. So you need to make sure you buy turbo plugs for those engines.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 02-01-2009, 03:23 PM   #9
CaptCrunch's Avatar
Originally Posted by chunk t View Post
Kris,
Awesome!! Thanks Chunk, that's exactly what I needed! The more I learn about nitro, the more it seem almost "mystical". There are alot more aspects to the sport than electric. Hopefully when I get to putting all this internet learning to practice it will start to fall into place.
Kris
