Old 02-01-2009, 12:08 AM   #1
Default Pull Start/Fly Wheel
Ok guys and gals need some help as I dont know where to go to from here.
Ran the engine in with 6 tanks of fuel just idling, an hour after the last tank ran through I decided to take the ride down to the park to have a drive, I went to turn the motor over and the pull start wont budge and inch, even with the plug out.
I am assuming its the fly wheel that seems to be jammed as well.
Everything went fine with the run in, is it a case of where things ended up stopping when the final tank of fuel ran out?
How can I free the pull startup, but I am guessing more to the point the fly wheel?
Help,
Cheers Mal
Redsea is offline   Reply With Quote
Old 02-01-2009, 02:17 AM   #2
new motors are really tight i had to get a flat head screw driver and literly pry my fly wheel free using the chasis as a brace
ruggydriver is offline   Reply With Quote
Old 02-01-2009, 02:23 AM   #3
Would you suggest putting it in the teeth and tapping clockwise to free it up, or something like vice grips, I dont understand how you used the chassis as a lever as such?
Cheers Mal
Old 02-01-2009, 06:50 AM   #4
littlelane's Avatar
try using a hairdryer or heat gun on the block first 190 degrees or so and next time you put it away make sure piston is on bottom
littlelane is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
REVO 3.3 RACE ROLLER WITH SERVOS COMES WITH A TON OF HOP-UPS AND PARTS MUST SEE!!!! Mechman518 R/C Items: For Sale/Trade 6 05-11-2008 06:34 PM
