Old 01-31-2009, 08:09 PM   #1
redza's Avatar
Default mesh? sounds yummy.
i hear that i need to reset a mesh when mountig an engine? whats is mesh?
Tebo is the man.
redza is offline   Reply With Quote
Old 01-31-2009, 08:10 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Your spur gear and clutch bell gears will "mesh" together if its too far you will chip gears, if its too close, you will strip gears, and blow bearings.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-31-2009, 08:12 PM   #3
redza's Avatar
how do i mash the mesh?
Tebo is the man.
Old 01-31-2009, 08:15 PM   #4
fast11970's Avatar
http://www.youtube.com/watch?v=Fa8bGfexpLs
This kinda shows you what your looking at...I do it by feel, but I used to used parts bag plastic on my Buggy Instead of paper, I think you deal with alot more chassis flex in 1/8 scale off road...
Hope this helps. Skip to the middle...
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 01-31-2009, 08:16 PM   #5
Jaz240's Avatar
Just keep smokin what you got, I'm sure you'll mash em pretty good
Old 01-31-2009, 08:25 PM   #6
when you put the gears together slide a piece of paper through them and take it out. There should be defined teeth in the paper but no ripping. If it is ripped its too tight and if there are no teeth then its too loose.
rgrassey@me.com is offline   Reply With Quote
Old 01-31-2009, 08:30 PM   #7
redza's Avatar
he said for nitro vehicles i need to use 2 peices of paper? meaning samething what he did but with the 2 pieces of paper between the bell and the spur right?
Tebo is the man.
Old 01-31-2009, 08:34 PM   #8
jrwoodchuck's Avatar
yup, tight enough to crimp the paper but not cut.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 01-31-2009, 08:46 PM   #9
fast11970's Avatar
Mke sure you check it 360 degrees, cause sometimes it will be tight, then loose, just see if it feels the same 360..FYI
MBX6
Old 01-31-2009, 10:18 PM   #10
8&stuff's Avatar
Trader Rating: 55 (100%+)
the right thickness of paper helps too. my losi manual is perfect. when you roll the spur back towards you be sure the paper sags back your way as well. be sure to take time to get mesh set correctly. quick change mounts can help you out a little in the long run.
Mark Buecker
8&stuff is offline   Reply With Quote
