Old 01-31-2009, 04:06 PM   #1
Trader Rating: 27 (100%+)
Default CVD Pins Where to buy
Who changes their own cvd pins and where do you buy them? I've seen the tools, but never hear to much about this. Surprised nobody does it along with an engine pinching service..
I'm looking for rc8 pins, are they pretty much interchangeable?
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 01-31-2009, 04:26 PM   #2
vladconnery's Avatar
Trader Rating: 35 (100%+)
http://www.carolinasrc.com/Webstore/...idproduct=7760 I do my 8's pins it's a whole lot cheaper.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 01-31-2009, 04:27 PM   #3
Jaz240's Avatar
Trader Rating: 52 (100%+)
Look in your manual for part number you can buy them anywhere that stocks AE parts. They are almost immpossible to change without a tool, Hudy makes on, and there is something called a bonesaver, or you can try a chain break tool. You should do some more research before you try this at home..its not as simple a task as it sounds
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-31-2009, 04:46 PM   #4
I'm sure it's brain surgery.
I'll look and see if the rebuild pins work in the other end as well. Also will try some mugen pins since they sell em in packs without the rebuild parts.
Old 01-31-2009, 07:26 PM   #5
Jaz240's Avatar
That's not what I meant, could've done without the comment... I was trying to be funny, like TV when someone does something stupid or dangerous and they say dont try this at home...anyway...its not as simple as just press out the old pins press in the new...they have to be set right, even, and i have heard people using threadlock, and people expanding the holes by accident and they lost the pins while running...i was just letting you know in a stupid kind of way to do some more research before you just go and do it..you dont want to lose the pin after everything
Old 01-31-2009, 08:04 PM   #6
Ok, I wasn't sure how to take it but now I know. And it makes it funny now as I know just what you mean. lol
And I found a bunch of other threads on this subject, so I probably should've used the search .. It never used to work on these forums, but they've got it set up pretty good now. Thanks for setting me straight with the comment.
Old 01-31-2009, 08:06 PM   #7
Jaz240's Avatar
Good luck
Old 02-01-2009, 07:41 AM   #8
Trader Rating: 19 (100%+)
Yeah I always wondered why the companies didnt make that end with a set screw like the other end. I guess that would make things alittle cheaper and easier on us LOL. But to be honest I always had wear on my center bones or cvd's which ever they were but never had to swap pins or buy new cvd's for the driveshafts only the diff cups, wierd now that I think about it.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 02-01-2009, 01:26 PM   #9
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
I use the Hudy pin replacement tool and it is as simple as push the old one out and push the new one in. Out of 25+ pins that I have replaced, never had an issue with the pin coming out. I've used mugen pins and Hudy pins. Hudy seemed to last just a tad bit longer but the mugen pins are fine.
KIK is offline   Reply With Quote
Old 02-01-2009, 04:07 PM   #10
KIK did you use threadlock or anything?
TTST4G3 MT4ed out
Old 02-01-2009, 07:26 PM   #11
KIK
KIK's Avatar
No, I haven't used thread lock. I've changed pins out of Ofna Crt, Mugen, and Losi shafts. All 3 uses the same size pins but the Kyosho st-rr and the MP777 are a slightly smaller pin. I have yet to find pins for the Kyosho.
Old 02-01-2009, 09:03 PM   #12
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I also use the Hudy tool and mugen pins. Last week I did all the pins on my Losi. The Mugen pins are slightly shorter that the Losi pins but they seem to work fine.
By the way I dont recommend the Hudy tool. I think its harder to use than the Bonesaver. Last week while using it the pin inside the tool that pushes out the old pin broke of nearly taking my eye out (I should have been wearing glasses). Now I cant get the broken pin out of the tool so it might be junk. It still paid for itself with all the pins I replaced.
infanterene is offline   Reply With Quote
Old 02-02-2009, 12:27 AM   #13
I just use small hex socket to round part of the dog bone and a vise to press the pins out. As for the pins, I get them from Mcmastercarr.com. Just make sure you get the harden one instead of the SST (soft). And also get the pins 1mm longer than you need, cause the ones they sell has a 1mm chamfer at the end.
chumanji is offline   Reply With Quote
Old 02-02-2009, 03:27 AM   #14
Thank you Sir, thats what I realy wanted to know.
The Working Man is offline   Reply With Quote
Old 02-02-2009, 07:03 AM   #15
Integra's Avatar
ive heard/seen multiple guys loosing pins due to No Loctite......don't be Ignorant and not use it....it's not like it's expensive...and RED not Blue.
TC3 Forum Lowrider Electric On-Road 12162 12-30-2016 04:19 PM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
"Tamiya Class" racing...Help me choose - TA05 vs TA05R pgeldz Electric On-Road 84 08-09-2008 09:03 PM
