Old 01-30-2009, 09:30 AM   #1
redza's Avatar
Default replacing an engine
lets say, i bought a 8ight RTR, and i want to replace the engine with a novarossi, i open the box of the rtr and then i unscrew the rtr engine on the engine moun, to remove the clutch all i need is a screwdriver and a flywheel puller to remove it right? and the shoes are intact, so i basicly i just unscrew the bell and remove the flywheel nut and remove the flywheel? and reassemble everything on the novarossi engine?
its an example. not a true story
Tebo is the man.
redza is offline   Reply With Quote
Old 01-30-2009, 09:35 AM   #2
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Yep, take off every thing the new engine doesnt and put it on the new engine
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-30-2009, 09:36 AM   #3
BAUSTIN's Avatar
unless the Nova is pull/roto start, you would need a set of motor mounts and a starter box
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 01-30-2009, 09:44 AM   #4
pballer2777's Avatar
Trader Rating: 27 (100%+)
the rtr motor mounts r too high. u will not b able to bump the motor to start it.
pballer2777 is offline   Reply With Quote
Old 01-30-2009, 10:04 PM   #5
redza's Avatar
then how?
Tebo is the man.
Old 01-30-2009, 10:06 PM   #6
pinky2252s's Avatar
then how?
A bigger fly wheel
Team Terribles
Old 01-30-2009, 10:11 PM   #7
redza's Avatar
can you recommend a bigger flywheel? meaning i ahve to put together a new clutch?
Tebo is the man.
Old 01-30-2009, 10:13 PM   #8
You need the kit engine mounts.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 01-30-2009, 10:15 PM   #9
redza's Avatar
is this the one from the kit?http://www.amainhobbies.com/product_...oducts_id/9001
Tebo is the man.
Old 01-30-2009, 10:55 PM   #10
losi_racer's Avatar
Trader Rating: 25 (100%+)
yes, put those mounts on and then bolt then new engine up, dont forget to shim the clutch when you put it on the new motor
and you dont need a flywheel puller with the losi 8ight clutch, just smack the back of the flywheel with a rubber mallet or a screw driver that has padding on the handle
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-30-2009, 11:29 PM   #11
omarwashington's Avatar
To make it eaiser to remove the clutch shoes I use this:
http://www.amainhobbies.com/product_...oducts_id/4663
You can use a mallet to remove the fly wheel, but I donít recommend it. Rather, I use a Battery Terminal Puller which you can find in your local auto supply store for about 10$ to 20$. Or you can buy this:
http://www.amainhobbies.com/product_...oducts_id/4098
omarwashington is offline   Reply With Quote
Old 01-31-2009, 12:14 AM   #12
losi_racer's Avatar
the losi clutch is the most user friendly clutch out there, you dont need any tools. all you do is unscrew the pin and pull it out and the clutch shoes fall off the flywheel, to reinstall just round the end on the clutch pins and you push the pin thru the pad and spring and screw the pin in, roundin them makes them slide right in. no tools, no pain. my dad who takes for ever to take apart the buggy can change a clutch from start to finish in no more then 5 min, anyone who says you needs tools or anythin else on a losi clutch are just morons
Old 01-31-2009, 01:15 AM   #13
redza's Avatar
what does shim the clutch means? im new to this hobby,
Tebo is the man.
Old 01-31-2009, 03:28 AM   #14
redza's Avatar
no, seriously, whats shim the clutch?
Tebo is the man.
Old 01-31-2009, 08:32 AM   #15
rced1's Avatar
Trader Rating: 17 (100%+)
The clutch and bearings tend to expand as they heat up. So you need about .10 of play on the clutch bell when mounted on the motor shaft. Too little play and the bearings can become damaged. Too much play and the bearings can cause problems too.
Shimmimg the clutch refers to adding or removing shims on the bolt that holds the clutch bell on to get this play.
rced1 is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Optional cooling heads speedy2 Nitro Off-Road 12 01-25-2008 12:30 PM
Tuning Guide for Nitro? K_King Electric Off-Road 6 02-16-2007 03:51 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
