Old 01-31-2009, 10:04 AM   #16
losi_racer's Avatar
Trader Rating: 25 (100%+)
put the bearings,clutchbell, and nut on..... see how much play back and forth the clutch bell has it should be NO MORE then 1mm of play, you learn to just know when the space is right when you do it a couple times,check to see if the clutch bell is hittin the flywheel if it is then you need to put a shim between the flywheel nut and the rear clutch bearing.
if its not hittin the flywheel and you still have to much play then put shims in between the outer bearings and the clutch screw(the very outer screw that screws into the crank ).... I put in one at a time. all you want is enough play so when everythin heats up it will be tight,like i said you'll learn this as time goes on.... whats best to do is shim the clutch then take it to someone who knows what they are doing,perferbly an expert, not someone who just acts like one, this will help learn that sweet spot, this is what i did and it helped a lot
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-31-2009, 08:03 PM   #17
redza's Avatar
might as well remove the clutch system from the rtr engine and bring the nova rossi engine to the LHS, they would know how to install it
Tebo is the man.
redza is offline   Reply With Quote
Old 02-01-2009, 07:02 AM   #18
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
redza. i see alot of questions about alot of basic things being posted.
this link may save you some time in your quest for rc understanding..
http://tinyurl.com/bnnrxg
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Optional cooling heads speedy2 Nitro Off-Road 12 01-25-2008 12:30 PM
Tuning Guide for Nitro? K_King Electric Off-Road 6 02-16-2007 03:51 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
