Old 01-29-2009, 05:11 PM   #1
markr04's Avatar
Unhappy I can't remove my shocks. n00b alert.
n00b alert.
I'm trying to remove the shocks from my Mugen MBX-5 Prospec. I removed the nut and screw from the shock tower and that went fine. I removed the screw from the lower arm.
I can't get the shock out of the arm. I can see what looks like a metal ball joint or something down in there. I even took a screwdriver and hammer to the underside of it and it still won't come out. All four of the shocks are like this.
wtf.
Thanks.
markr04 is offline   Reply With Quote
Old 01-29-2009, 05:18 PM   #2
Take a hex driver from the top of the arm, and slide it under the arm. Then push the hex driver down and it should come off. Just need a little elbow grease.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 01-29-2009, 05:18 PM   #3
Fasten the shock back onto the shock tower, leave the bottom screw out. Then push down hard on the suspension arm, should pop right out. You might have to relieve the droop adjustment screws if the arms wont go down far enough, depends on what your setup is like. If you do be sure to re-set your droop.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 01-29-2009, 05:40 PM   #4
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
+1 that is what i do if they are being stubborn
jamminnay is offline   Reply With Quote
Old 01-29-2009, 05:58 PM   #5
markr04's Avatar
Thanks guys. Got one off so far!
