Old 01-28-2009, 04:28 PM   #1
Default Truggy isn't sucking gas into the motor.
Anyone have an idea why? We've cleaned it and we even disconnected the tubes and blew air through them. When I put gas straight into the carborator it starts up, but not when I don't do that. It's not getting any fuel. Any suggestions on what I can do? Thanks.
Dvx400Rider is offline   Reply With Quote
Old 01-28-2009, 04:31 PM   #2
VenturaDC's Avatar
Trader Rating: 32 (100%+)
take the HSN all the way out and clean inside and out of that part of the carb. while its out blow into the line to make sure the nipple isnt clogged
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 01-28-2009, 04:42 PM   #3
Chill_Will's Avatar
Check your fuel tank and make sure the lid seals. Make sure you have the fuel lines going to the right places. If you have a filther make sure its not clogged. Try new fuel tubes. Try what Venturadc said, make sure your needles are not clogged.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 01-28-2009, 04:54 PM   #4
What's the HSN, I'm new to this kinda thing <_<
Old 01-28-2009, 04:57 PM   #5
Wildbillsphotos's Avatar
Trader Rating: 31 (100%+)
Send a message via MSN to Wildbillsphotos
What motor is it?
Life is too short - Hug your kid's often!
Adopt a pet and save a life!
Visit My Website: www.WildBillsPhotos.com
Mel's Shells-n-Sticky Things!
Wildbillsphotos is offline   Reply With Quote
Old 01-28-2009, 05:00 PM   #6
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
high speed needle
R
UltegraSTI is offline   Reply With Quote
Old 01-28-2009, 05:11 PM   #7
Originally Posted by Wildbillsphotos View Post
What motor is it?
It's an HPI, I think it's a 4.1, or maybe a .28 I'm not too sure.
<i>high speed needle
R </i>
Alright thanks man.
Old 01-28-2009, 05:14 PM   #8
Integra's Avatar
Gotta love HPI quality.
Old 01-28-2009, 05:16 PM   #9
The HSN (high speed needle) is on top of where the fuel goes into the motor.
Old 01-28-2009, 05:26 PM   #10
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
The one thats sticking out of the carb
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-28-2009, 05:35 PM   #11
I also have a pico 0-1, a cen .21 and a Losi Mach 427. They all need a rebuild. That Hpi is the only one that doesn't.
Old 01-28-2009, 06:33 PM   #12
Illbreakthat's Avatar
First i would check the obvious.. unhook the fuel line from the carb and place it into a container.. using the fuel line from the exhaust i would blow into it to make sure the fuel is flowing and if it flows properly then it may be your carb has junk build up and it may just need to be cleaned.
Not much to put here....
Illbreakthat is offline   Reply With Quote
Old 01-28-2009, 08:51 PM   #13
I took the line off and blew into it. Did this for both and air went through both. I think I have to get a new rubber piece that goes on the back of the hedder where the pipe connects to the engine. It's kinda old.
Old 01-28-2009, 09:09 PM   #14
Jaz240's Avatar
Trader Rating: 52 (100%+)
Is it priming? If not she's suckin air somewhere
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-28-2009, 09:28 PM   #15
priming? What's that?
