Old 01-28-2009, 09:37 PM   #16
Jaz240's Avatar
Trader Rating: 52 (100%+)
Hold your finger over the end of the exhaust pipe and try to start the engine. If you see fuel running through the fuel lines into the plastic thing that has the air filter attached to it, then it is priming. if the fuel stays in the fuel tank and dont move through the lines, you are sucking air....You need to get to a hobby shop, with all due respect, you are way to new to even understand the help we are trying to give. go to a hobby shop, and ask them for help
What you need just cant be done online
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-28-2009, 09:46 PM   #17
I'm not too new to understand. I just wasn't thinking that's what you meant. I already did that and no gas through the lines. I think it's sucking air on the back where the pipe connects to the header. The rubber piece is like, no good.
Dvx400Rider is offline   Reply With Quote
Old 01-28-2009, 09:48 PM   #18
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
He might sound rude but its true, you need to be taught be looking at someone else do it, thats a good way to learn!
Dont be shameful lol, i had to go back and forth A LOT to my hobby shop...
My very first engine, i was sort of dumb and uh.. put GAS in to the tank they took my engine apart and the guy said he smelled gas on it, i was so embarassed but he was cool and he even GAVE me a few parts to fix it!
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-28-2009, 09:51 PM   #19
pinky2252s's Avatar
Coupling
There like 2 bucks at a hobby shop and there pretty much universal
Like these: http://www.amainhobbies.com/product_...ducts_id/27269
There a bit over priced but im SURE your hobby shop has them
Team Terribles
Old 01-28-2009, 11:02 PM   #20
losi_racer's Avatar
Trader Rating: 25 (100%+)
replace both gaskets while your at it, heres the other one
http://www.amainhobbies.com/product_...oducts_id/6364
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-29-2009, 12:23 AM   #21
Lol I just wasn't thinking about priming. That's it. I knew what he meant the second he explained it...
Old 01-29-2009, 12:26 AM   #22
These are what I need! Thanks bro.
Old 01-29-2009, 12:33 AM   #23
losi_racer's Avatar
np. that gasket gets forgotten alot but its a VITAL point in the exhaust system, hopefully thats all thats wrong
Old 01-29-2009, 12:41 AM   #24
Yeah I hope so. I don't think that it's getting enough suction cause of the one that's on there. I'm also going to clean the HSN just in case <_<
Old 01-29-2009, 12:48 AM   #25
losi_racer's Avatar
replace the fuel line and pressure line also. its not expensive and its just piece of mind.....
if your comfortable with your skills. you could take the whole carb apart and clean the whole thing.
Old 01-29-2009, 01:41 AM   #26
My uncle is really good with the RC cars, we're going to just try the gasket part. The little rubber pieces lol. Thanks for the help man.
Old 01-29-2009, 07:10 AM   #27
Jaz240's Avatar
Did I sound rude!? I wasn't trying to sound rude, I was being honest. How can an air leak be detected online, without knowing all the terminology?
Apologies DVX I wasn't trying to be rude
Old 01-29-2009, 12:28 PM   #28
Lol no you didn't sound rude, chill dude. You were just trying to give me some helpful advice haha.
Old 01-29-2009, 02:22 PM   #29
slaytanic's Avatar
Trader Rating: 20 (95%+)
Pull the fuel line off of the HSN on your engine and blow into your exhaust. If fuel comes out you are good there. That means most like likely that your high speed needle is clogged. That is the needle where you hook the fuel line into the engine. The key is to isolate 1 thing at a time.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 01-29-2009, 02:47 PM   #30
CaseyP's Avatar
after you have checked the carb etc check the pipe.
If you have a pipe that has an external nipple (for the pressure line) make sure it is clear. use a piece of wire or something to shove thru. If your pipe does not and uses a hole to poke the line into make sure it is not pushed in too far and hitting the other side of the pipe. The way to fix this for good is to cut the fuel line at a 45 deg so it will never plug if pushed in too far.
good luck
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
