Old 01-27-2009, 09:36 PM   #1
rdcracer's Avatar
Default Different Diff oil effects
Can someone explain to me the effects of changing diff oil. I am running 5000,7000,2000 in my eight. If I go up or down in viscosity how does it change the handling? These types of diffs are new to me and I have no idea what I am doing.
R & RC TIGHTWAD RACING
Where any price is too much.....
BMI 1/10 & 1/12 Copperhead
Scapel, Losi 22, Jammin SC10, Wraith
rdcracer is offline   Reply With Quote
Old 01-27-2009, 09:43 PM   #2
vti-chris's Avatar
Heavier front diff oil will loose some off-power steering but the car will be smoother entering turns and easier to drive.It will also pull better out of turns.
Heavier center will also loose some off power steering but the car will give more on power steering and more acceleration
Heavier rear will loose some off power steering but will slight better on power and the rear will feel like it has more traction because it won't tend to loose suddenly the grip as it might happen with 1000 diff oil(not always the case though).
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 01-27-2009, 09:43 PM   #3
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Its affect btw
But back on topic, a higher number will be a thicker oil, making your diffs run a little slower but smother power, a lower number will be thinner so if you were to full throttle it will most likley spin the tires (on dirt) more then it would will a higher number oil
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-27-2009, 10:08 PM   #4
Go to the link and download the Hudy Off-Road & Truggy Setup Guide. 3rd down on left. This has everything you need to know about what changes do what when it comes to diff oils and everything else you may have a question about.
http://www.teamxray.com/teamxray/pro...ria=0&catName=
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 01-27-2009, 11:11 PM   #5
Actually, "effect" is correct as used. He was asking about the effects of using different weight diff oils (correct usage of the word here).
If he had said "How will different diff oils AFFECT the handling of my buggy ..." (or something like that), then "affect" would have been correct.
glolar is offline   Reply With Quote
Old 01-28-2009, 05:12 AM   #6
rdcracer's Avatar
Thanks NCWC, the website is exactly what I was looking for. I have been running onroad for so long, Getting back into offroad everything is different now.
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
Locked front diff ????? freestyles Nitro Off-Road 8 10-30-2008 03:46 AM
Speedmerchant Rev.4 Yankey Electric On-Road 1413 02-22-2008 08:24 AM
T.R.C.R. Nitro Chat!.... TURBO JOHNNY Northwest Racers 167 02-14-2005 01:18 PM
