Old 01-27-2009, 04:23 PM   #1
aiyoaiya's Avatar
Default New Axe Mamba leaking...
i was breaking-in my brand new AxeMotorRossi Mamba the other day but i noticed there were some good amount of nitro all over my chasis leaking from the engine. i dun suppose it's normal, but i can't find out where was the leak... help needed please... anyone had the same problem b4???? any advice appreciated...
aiyoaiya is offline   Reply With Quote
Old 01-27-2009, 05:13 PM   #2
Losi Driva's Avatar
i would say it would be leaking from the front bearing, i had the same problem with a go-tech. Sometimes the seal just pops off the bearing but can be easily put back in.
Rhett Summers- Australia :P
Novarossi
Team losi
ko propo
proline
Losi Driva is offline   Reply With Quote
Old 01-27-2009, 06:54 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
That can be alot of things. Make sure your fuel lines aren't leaking and the carb fuel nipple is snug, tank not leaking, etc., Does your engine have the orange front bearing seal? They changed front bearings a while back, but I would assume the front bearing should not be dumping out fuel. If so, something is wrong. If the mixture is set properly, that much fuel should not be down in the crank nose. Maybe oil from break-in (rich mixture), but even at that, it should be sweating out, not leaking. Onroad engines run metal shields and fuel doesn't come out of the front nose unless someone flooded the engine, and it won't run when that happens.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
