Old 01-26-2009, 05:33 PM   #1
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
Default Removing tires with acetone
I have been baking my tires off for ages now but i have a heap to do and sick of burning myself on the hot rubber
If you use the "acetone in a bucket with the tires up out of the acetone" method. Does it ruin the foams?
I have about 12 sets of new tires on 1/2 offset rims that i want to get off and put onto standards for when my 8T 2.0 arrives
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 01-26-2009, 05:34 PM   #2
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Yes acetone ruins the foams and they will powder away if you use them again
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-26-2009, 05:48 PM   #3
Jaz240's Avatar
Trader Rating: 52 (100%+)
Dont waste your time...I did the acetone thing last week, and its cheeper to buy new rims and tires. Acetone is $40 a gallon and you need allot, tires need to soak for 24 hours, acetone soaks into the foam, and cannot be reused, plus most of the acetone evaporates even if you seal it, after all that work, I still needed to sand the rubber residue off the rims to re-use them, it would have been quicker, cheeper, and allot less work to just buy new tires and rims, and glue em up, or use the boil method..Hot water is free!!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-26-2009, 05:51 PM   #4
pinky2252s's Avatar
I bought a half a gallon for 4 bucks... were the hell are you buying it?
With the boiling method you can save everything
Team Terribles
Old 01-26-2009, 05:55 PM   #5
losi_racer's Avatar
Trader Rating: 25 (100%+)
it will still ruin the foams unless u plug the holes
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-26-2009, 05:57 PM   #6
pinky2252s's Avatar
Mine are fine... its just foam, you just have to let them dry fully...
Team Terribles
Old 01-26-2009, 06:00 PM   #7
Jaz240's Avatar
HOMEDEPOT! 1/2 gallon $18.99 plus tax! WTH did you get it for $4????
Old 01-26-2009, 06:10 PM   #8
pballer2777's Avatar
Trader Rating: 27 (100%+)
i tried the acetone thing last week and it was a waste of time and money. then i tried the boiling thing and it was like magic. i was able to reuse everything. make sure u boil them for like 20 min and if the tire still won't come off throw them back in. they will break loose.
pballer2777 is offline   Reply With Quote
Old 01-26-2009, 06:14 PM   #9
pinky2252s's Avatar
Sale!!!
Team Terribles
Old 01-26-2009, 06:25 PM   #10
Dstreelm's Avatar
So you just boil them in water?
I have a set of tires and rims for my NPede, it was my first attempt at tire gluing, and i ended up making them way off balance, so much so that they would flip my ride whenever i turned...so I can just boil them and try again?
Dstreelm is offline   Reply With Quote
Old 01-26-2009, 06:25 PM   #11
Jaz240's Avatar
Sale!!!
Sorry Pinky I cant get home made acetone in Phoenix for $4 a gallon...all the labs are too busy making Meth
Old 01-26-2009, 06:28 PM   #12
Jaz240's Avatar
Yes, boil a pot of water big enough to hold all 4 tires, or you can do 1 or 2 at a time if you like. Boil water first, throw in tires, use something heavy to hold them under the water, or they float, if they float you will have to boil both sides. 20-30 minutes later, pull em out 1 at a time, and use waterproof oven mitts to tear the tire from the rim, repeat 3 more times.....
If you got CA glue on your foams you'll need new foams, if not, make sure they dry completely before you rebuild
Old 01-26-2009, 06:29 PM   #13
pinky2252s's Avatar
Hahah, Nah, home depot had a sale lol
Team Terribles
Old 01-26-2009, 06:30 PM   #14
Jaz240's Avatar
Next week, I'm teaching RIT DYE...an awesome way to dye any white RC part rims/wings any color you want
Old 01-26-2009, 06:31 PM   #15
pinky2252s's Avatar
Already did the dye with my rims and spoiler
BAM
Team Terribles
removing glued tires? ROADRASH77 Nitro Off-Road 41 08-05-2009 07:48 PM
Removing Tires from Rim...Help chumanji Electric On-Road 9 05-14-2007 10:26 AM
NEED HELP>getting glued tires off of plastic rims old_fart_racing Electric Off-Road 16 09-21-2006 09:13 PM
Removing premounted tires leadacid1 Electric On-Road 19 11-18-2005 06:47 AM
REMOVING TIRES FROM RIMS wolfman76 Australian Racing 13 07-22-2005 03:24 AM
