Old 01-26-2009, 05:15 PM   #1
Exclamation nitro evader st problems
my transmission is making some weird noises. when i accelerate it grinds. it sounds like plastic but idk what it is. if i stand in front of the car and accelerate the slipper engages and turns but makes the grinding noise. when there is no resistance it doesnt make the noise. Any help is appreciated!!!
evader-fan-69 is offline   Reply With Quote
Old 01-26-2009, 07:14 PM   #2
chunk t's Avatar
Evader, I believe the Evader ST's basic format is similar to the older Maximum Pro ST. I know on the Maximums the slippers would make a nasty "chirppy" noise when they began to get warm. Not the most plesant noise. You can either live with the noise or you can change to a metal spur gear. At least that was the solution with the Maximum.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 01-26-2009, 09:13 PM   #3
its not the slipper clutch. its new and both the slipper clutch plate and backer are in good condition. is there some kind of gear that might get worn down..or maybe low on grease??
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 01:27 AM
Officiall Losi Desert Truck Thread. Shimmy Electric Off-Road 11 05-29-2009 11:06 AM
Good starter Stadium Truck? joe of loath Electric Off-Road 35 07-28-2007 11:32 AM
duratrax nitro evader aslipperyeel Electric Off-Road 6 10-12-2003 08:28 AM
