Old 01-26-2009, 02:37 PM   #1
Send a message via AIM to pedeboi364
Default XTM .18 needle settings?
I have an old t-maxx .15 with an XTM .18 engine in it (hand-me-down, it sucks). I was wondering what the factory needle settings were for it, and what i should do to get it running in 20 degree weather. Thnx!!
For Sale/For Trade: LOTS OF STUFF!!! PM me and find some deals!!
pedeboi364 is offline   Reply With Quote
Old 01-27-2009, 03:14 PM   #2
anyone?????
Old 01-27-2009, 03:20 PM   #3
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Screw the top end all the way down then back out 3 turns, for the low, make it flush with the carb that its sitting in. dont mess with the idle
If you have any old socks with an elastic band, cut the toe end out and pull the sock over the cooling head with the elastic down so it holds it on, it should keep it warmer. If you dont have and socks wrap the cooling head in foil.
Any more questions?
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-28-2009, 07:05 AM   #4
thanks man, I'll see how that works out... i have the idle at 1.5 turns out from flush, and that seems about good...
Old 01-28-2009, 04:06 PM   #5
pinky2252s's Avatar
Tell me how it works out
Team Terribles
Old 03-01-2009, 05:06 PM   #6
Finally got to take it out today and getting going OK. 3 turns out was a perfect starting setting, thnx pinky . I'm having problems however with the (apearently) LSN. It backs itself way the hell out when I'm running. However, I thought this was only a 2-needle engine (that was the description says on the XTM site, maybe they excluded the idle as a needle and meant high/low neeldes??) Any help there other than time for locktite??
Old 03-01-2009, 08:19 PM   #7
pinky2252s's Avatar
Well, i wouldnt suggest locktite because then you couldnt adjust it
Do they make a really really weak locktite? because that would prolly keep the screw in but make it still adjustable. If that doesnt work you could re tap it but that would be dangerous for your carb
Team Terribles
Old 03-01-2009, 08:27 PM   #8
MoparRules's Avatar
Send a message via AIM to MoparRules Send a message via Yahoo to MoparRules
blue locktite. its easy to remove but holds tight.
outa the hobby
MoparRules is offline   Reply With Quote
Old 03-01-2009, 08:34 PM   #9
BIG RE's Avatar
Trader Rating: 32 (100%+)
check the o-ring on the needle, it may just need replaced, if it is worn out, the ring will look flat on the outside, that is most likely your problem right there. I don't think the loctite would work with the oily conditions and the heat.
BIG RE is offline   Reply With Quote
Old 03-01-2009, 08:41 PM   #10
BIG RE's Avatar
http://media.hobbypeople.net/manual/146002.pdf
It appears that you would need part number TE12906. Have your local shop order it for you, if they are hooked up with global hobby distributors, they are the only one's that distribute XTM.
Old 03-01-2009, 08:55 PM   #11
MoparRules's Avatar
thats a good point. didnt even think of the o rings
outa the hobby
Old 03-01-2009, 09:00 PM   #12
BIG RE's Avatar
Old 03-02-2009, 04:40 AM   #13
yup, its the o-ring. thnx for the link BIG RE. any1 know if i could get the right o-ring at a hardware store?? thx
Old 03-02-2009, 06:41 AM   #14
MoparRules's Avatar
is the O ring still there? or is it gone completely? cuz if its still there i would take it to a store and see.
outa the hobby
Old 03-02-2009, 11:04 AM   #15
just took the needle out and there lay the torn remaims of and o-ring. it put it on a different indent on the pins and that seems to work (will fire it soon and see how running goes). concerning the 2 indents on the pin, am i missing 1.5 o-rings??
