Old 01-26-2009, 09:16 AM   #1
chad24's Avatar
Default Reciver Question
Hey guys i have reciently baught a ko propo with there new micro reciver. But i noticed that the aetana has like a heat shrink around the fiber wire, But the fiber wire is about 1 inch longer then what the heat shrink is, So is it safe to trim abit of the fiber wire away?
thanks chad
chad24 is offline   Reply With Quote
Old 01-26-2009, 09:25 AM   #2
wallot's Avatar
DO NOT shorten the wire. just leave everything in antenna tube.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 01-26-2009, 09:45 AM   #3
chad24's Avatar
What would happen?
Old 01-26-2009, 09:59 AM   #4
Trader Rating: 85 (99%+)
Originally Posted by chad24 View Post
What would happen?
All the new 2.4 receivers that I have seen have the same thing on them, do not trim the inner wire as it will lessen your receiver signal. I simply run mine through the antenna tube and then gently fold over the exposed piece and put the antenna cap on it. If you bend,kink, or cut the wire it will affect your receiver signal strength.
WideOpenThrottle RC is offline   Reply With Quote
Old 01-26-2009, 10:16 AM   #5
chunk t's Avatar
Chad,
All the different frequencies generate different wave lengths. 75Mhz, 27Mhz, 72Mhz, 2.4 Ghz (2400Mhz). The length of the transmitting and receiving antennas must be "tuned" to the frequency. An antenna is tuned through its length. Cut the antenna, and you change the frequency your antenna will operate at.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 01-26-2009, 10:23 AM   #6
chad24's Avatar
Default Thanks
Ok Thanks A ton guys.
1/12 forum ovalnator Electric On-Road 45709 Yesterday 05:19 AM
KO PROPO EX-10 Helios q's Kenshin Electric On-Road 2225 03-13-2014 01:04 AM
Ko Propo VFS-1 ESC Hebiki Electric On-Road 2492 10-14-2012 07:51 PM
Spektrum allrc Radio and Electronics 2545 07-17-2012 08:25 AM
LRP Q2 Question farls3589 Electric On-Road 19 11-25-2005 04:21 AM
