Old 01-27-2009, 07:35 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Joe_Racer View Post
Hey Monty, any comment on my post?
ofna pipes are awesome , just brittle casey should be able to tell you the best combos he is a sponsored novarossi racer .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 01-28-2009, 03:07 AM   #17
Originally Posted by houston View Post
biased???
run what you are used to , i have put many nova carbs on trinity, OS and GO engines and they all ran better after doing so
Well, maybe I'll try my Nova carb in a different engine, funny how so many engine parts mix
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 01-28-2009, 07:44 AM   #18
Joe_Racer's Avatar
Trader Rating: 31 (100%+)
Monty,
I already have Casey's opinion, I was looking for yours. Do you think that the Dynamite pipes are as good as Novarossi pipes? And does the increased run time and better top end come from the pipe combo or adding the shim?
Jack G.
Mugen MBX-7 Novarossi Plus 4, Mugen MBX-6TR Novarossi P5
RC10 GT2 OS TG, RC10 B4.2 17.5, SC10 FT 13.5, RC10 T4.1 13.5
Joe_Racer is offline   Reply With Quote
Old 01-28-2009, 07:51 PM   #19
Mark Erce's Avatar
Trader Rating: 77 (100%+)
Default nova
ok well there seems to be quite a few combos to choose from. can someone tell me if i run 20-25% fuel what plug should i run? i wanna stick with a nova plug since it will go in a nova engine. but what plug should i get? and as far as pipes go; os 2050,ofna/dynamite 053/086,nova9886??? i have a ofna jp-4,will this be suitable for this engine?
Mark Erce is offline   Reply With Quote
Old 01-28-2009, 08:13 PM   #20
houston's Avatar
Monty,
. the funny thing is , i have had ohhhhh lets just say a few pro drivers ask me for my advice on engine particulars and tuning ( i think i have a problem and need a proffesionals help, its a serious addiction)and i am respected by many people as knowing way too much about big block nitro mechanics , tuning and how to make the engines perform as you want without making them overperform as some modders do its about having a great useable power rather than having stupid insane power that gains you no improvement in driveabilty or lap times . come see me if you want when i am at the pit from friday to sunday . actually , i guess casey and the AZ fast guys have chose to hold a "tuning 101" class this weekend at the pit so there is another option for ya joe racer
happy motorin',
monty
Old 01-28-2009, 09:43 PM   #21
Joe_Racer's Avatar
happy motorin',
monty
I am going to try to make it out to the Pit this weekend, however, there are those that don't live in AZ that might be interested in an answer to my question on the shimming. If it improves run time and top end is there any reason not to do it. I also wonder why Novarossi sets up their engines for 25% nitro when that % is not something you can buy off the shelf. I, in no way mean any disrespect to you or your knowledge. I just like to hear different points of view, and when someone has a certin point of view I like to hear the logic behind their thinking. It sounds like Casey doesn't like Dynamite pipes but you do, so I just wanted to know why you do. I race on a budget and Dynamite pipes are a lot cheaper than Novarossi pipes, every vehicle I have has a JP pipe on it, but you said JP pipes work very poorly on Novarossi engines. If JP pipes are as non compatible with Novarossi engines as you say they are, thats a lot of money to switch all those pipes. Stav thinks the world of you, and based on what he has said about you I look forward very much to meeting you and picking your brain for info. Hope to see you Sat.
Jack G.
Old 01-28-2009, 10:00 PM   #22
houston's Avatar
the.10mm shim makes for an easier break in(sometimes i add .20mm worth of shims for run in period), improves the top end and tunability of the engine , it is not 100% necessary but many of the engines run a bit better with the shim added . as far as dynamite pipes , they are the best in durability and performance for the money granted the nova pipes are awesooommmeee! but $$$$$ very pricey the ofna pipes are not actually true specs to the number designation but they are awesome as well in the way they resonate and make big power . i like them but they are also brittle
monty
Old 01-29-2009, 01:36 AM   #23
motomanpat's Avatar
Monty,
One of these days I am going to look for my 2 stroke notes from MMI and do some skimming. I am sure some of that information would be usefull. I think I even had some notes and calculations for making pipes/porting/port mapping/performance gains and RPM goals.
motomanpat is offline   Reply With Quote
Old 01-30-2009, 03:13 PM   #24
Questions??
Ok, now I've done some tidying in my hobbyroom. And I took off my old unidentified pipe from my RB-S3, just to replace the bend from my JP4 (broken).
Now I have this lying around:
- Novarossi 2015
- JP 4 (currently on my P5X)
- JP2
What would You advice me to use on my P5X, and any thoughts of the best choice for the RB-S3 (so far only used wit the unidentified and the JP2).
MBX-6
Old 01-30-2009, 03:34 PM   #25
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
- Novarossi 2015
- JP2
I think the JP-4 would be the best on the P5X. I believe the S3 works best with a RB 2020 or Sirio 2013. Not sure about the NR 2015. Thats an onroad pipe.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-30-2009, 03:41 PM   #26
helivaguy's Avatar
Trader Rating: 42 (100%+)
i use 20% with a mc8 and ofna 086 in my hyper 8.5 and my p5x couldnt be happier.
helivaguy is offline   Reply With Quote
Novarossi engines thread EVOLUTION Onroad Nitro Engine Zone 5360 08-14-2017 11:48 PM
fairly new losi 8 buggy with novarossi p5x and starter box will g R/C Items: For Sale/Trade 66 09-05-2008 06:29 AM
A quick Novarossi Plus21 question air8 Nitro Off-Road 44 08-30-2008 02:18 AM
Ok.... The question! not to start a war... Bullseye101 Nitro Off-Road 12 02-29-2008 07:51 PM
