Old 01-25-2009, 07:20 PM   #1
dishsoap's Avatar
Default Roto start conversion
Hey guys. Is there anything special that I have to do when pulling out the pull start on a hyper 7 and recplacing it with a rotor start back plate. Is it pretty straight forward.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 01-25-2009, 07:40 PM   #2
dishsoap's Avatar
do the sun gears inside the roto back plate have to oiled or greased. If so can I just use diff silicone oil or wd 40
Old 01-25-2009, 08:17 PM   #3
dishsoap's Avatar
Also the glow plug came with two copper shims. Do i use both of them. This hyper 7 has alot of diffrences than my L 8.
Old 01-25-2009, 09:22 PM   #4
dishsoap's Avatar
anyone??? I am trying to get everything set up tonight so my son can run it tomorrow. Thanks in avanced.
Old 01-25-2009, 10:08 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
use 1 shim, use the pullstart until your engine is broken in, or you will ruin your bearing, and your start shaft....$40 to replace them..., dont put anything on the gears in the roto-start...dont use diff oil on anything but inside your diffs...WD-40 makes plastic shine..dont use it for anything else, get Mobile synthetic grease for your pinion gears..its a red paste comes in a tub..$9 lasts the rest of your life. maintain your car and your bearings, or things start to fail...i'm tryin here bud
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-25-2009, 10:14 PM   #6
dishsoap's Avatar
Ok thanks Jaz. You have been very helpful. I put the roto back plate on already. I will just take if off and put the pull start back on for break in.
Old 01-26-2009, 07:25 AM   #7
Jaz240's Avatar
Let me explain why:
The engine you are putting the roto-start on is not made for a roto start.
The one-way bearing, and the shaft that turns it is made for the slow pulling on the rope, not the immense speed and torque that the roto-start is going to create.
What happens is the roto-start is actually too strong and especially when the engine is new and tight. The roto-start wears away at the shaft, and the one-way bearing because it spins it so hard it actually strips the metal.
You can use it immediately if you want, but you will be replacing those 2 pieces after about 1/2 gallon of fuel.
You will still need to replace those pieces regularly, you will know when they need it, as the starter will spin, but your flywheel will not. I would advise you have at least one shaft, and 1 bearing with you for when they fail. you dont want failure in the middle of the desert.
Buy / Sell BoardSlapper Canadian R/C Scene 11025 08-15-2017 08:02 PM
Spektrum Ready LST2 w/ LRP Z.28R & JP3 Kausekaos R/C Items: For Sale/Trade 9 08-10-2009 07:07 AM
