Old 01-25-2009, 05:04 PM   #1
dishsoap's Avatar
Default Radio Problems With Brand New Hyper 7 Help!!!!
Hey everyone
I just opened the box up on my sons new hyper 7. I installed all of the AA batteries required. The hand held radio works as i can see its getting power. The problem i am having is that i cannot get any power to the radio tray. Its like its dead. I took off the switich cover to double check all of the connections and everything is fine.
I cant get any of the servos to work as is seems there is no power going to them.
Needless to say my son is upset. Any help would be really great
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 01-25-2009, 05:08 PM   #2
jamiekerr14's Avatar
Sounds stupid, but have you chaecked that the Rx Pack Plug is the correct place+Way round in the reciever??
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 01-25-2009, 05:09 PM   #3
Jaz240's Avatar
Trader Rating: 52 (100%+)
Check the plugs on the end of the battery clip, look inside the clip, make sure they are not bent or broken, make sure the male and female are touching when you plug them in. make sure the batteries are installed the right way...try the batt pack from your losi
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-25-2009, 05:14 PM   #4
dishsoap's Avatar
good idea i am going to try the battery pack from losi right now.
Old 01-25-2009, 05:16 PM   #5
Jaz240's Avatar
call me if you need to , James
Old 01-25-2009, 05:21 PM   #6
dishsoap's Avatar
Old 01-25-2009, 05:23 PM   #7
kvrc's Avatar
check the 4 batts in the reciever clip. i have found that soemtimes the batts need to be rolled around to get a contact. to check this further if you have a multimeter check for voltage at the terminal end with the clip unplugged from the car.
kvrc is offline   Reply With Quote
Old 01-25-2009, 05:25 PM   #8
dishsoap's Avatar
Ok the good news is it may not be a major problem. I just tried the battery pack from my losi 8 and it work perfect. So the problem is isolated to the AA battery pack. I checked the connectors from the battery pack and its fine. I wonder why the AA battery pack will not work.
Old 01-25-2009, 05:43 PM   #9
dishsoap's Avatar
well i dont know what i did but i got it fixed the AA battery pack is working now. I just took everything apart and put it back together and its working. Before i started this thread i swear i tried it 5 times without success
OK second problem. I got the servos trimmed at zero. Both break rods or linkage rods hit the gas tank when i engage the throtle. The break rod on top hits the gas guard and the one on the bottom acutally hits the tank. When the both touch the tank the tank moves. Is this normal. I am assuming that i need set them to a different setting.
Old 01-25-2009, 05:50 PM   #10
Jaz240's Avatar
Its normal, the tank is on spring posts, but it wont hurt to clip the ends of the brake rods with a wire cutter or dremel. leave 5 mm past the collars for adjustment
Old 01-25-2009, 06:07 PM   #11
Jaz240's Avatar
Dish PM
Old 01-25-2009, 06:29 PM   #12
dishsoap's Avatar
Dish PM
Sent PM back to you.
Thanks guys. Shoot I wouldnt know what to do if is wasnt for everyone here. Thanks to all. Geez if its not thing its another. Pateience gets tested everday.
Old 01-25-2009, 06:33 PM   #13
dishsoap's Avatar
Do I have to do anything special when pulling out the pull start and replacing it with a roto start.
